41 B piston rings
donwisc
03-17-2005 02:27:03
Have got only 30 psi on ea cylinder while pulling the tractor. Then put a Air fitting in the petcock hole and put 100 psi in the cylinders. No air escaping from intake or exhaust but lots of blowby thru cyl into crankcase.
Will now tear into it to see if rings stuck or need replacement. Did some checking on sources for rings and so far only found kits for the later Bs 200000 and up.
Is this going to be a problem finding a source on the early Bs?
I havent checked with the Deere dealer yet but will do so today.
jgc
03-18-2005 17:04:04
 Re: 41 B piston rings in reply to donwisc, 03-17-2005 02:27:03
niagara piston ring works can make rings any size if you can't find a ready source.
Rockbasss
03-17-2005 23:15:56
I don't know anything about this place, but someone somewhere mentioned it in a post and I saved the information.
PUTT PUTT
03-17-2005 09:52:17
Hastings has them. Earl
Stan - Florida
03-17-2005 05:21:14
Make sure your cylinders have not been bored out before you order rings. I didn't and ordered standard rings (part number AB 3725R), then took the head off and the pistons out. Guess what - it had been bored out to .045 over (part number AB 3727R for the .045 over rings).
Verify the above part numbers before you order them...I think these are right, but I was wrong once before.
Stan
Will P
03-17-2005 04:37:13
Don, about 3 years ago my 43B rings cost me about $50.00 from Twinkles.
Will in Wis
xragman
03-17-2005 07:21:04
 Re: 41 B piston rings in reply to Will P, 03-17-2005 04:37:13
will need better add.for twinkles please.
