How to fix ovalized holes in #45 loader
Dave in CT
03-16-2005 21:49:57
I'm restoring a #45 loader. The holes in the frame where the rear cylinder pins fit through are ovalized from wear. I suppose I could weld plates on the outside and use longer pins but I was wondering if anyone had a neater fix. Is it possible to fit some bushings into this location? The frame appears to be of 3/16" thick steel.
Skip in CT
03-18-2005 12:56:44
 Re: How to fix ovalized holes in #45 loader in reply to Dave in CT, 03-16-2005 21:49:57
I had a dipper cylinder with a bad rod and had a new one put in at C&C Hydraulics in Terryville CT. It looks like they have parts for everything related to hydraulic systems. Phone number is 800-322-2925. Good Luck.
Skip in CT.
Loren-MN
03-17-2005 11:43:58
I you are talking about the pin that attach or hold the rear of the loader to the axle brackets, they are oval from the factory. All they do is hold it in place so the loader can't work up on the axle bracket. Not sure what the concern is. If they are oval horizontal, I'd just fill in with weld.
JDBert
03-17-2005 07:27:00
Depends on how bad they are ovaled out. First thing to do is get new pins as I would guess that they are wore too. What we used to do on payloader is fill the hole (not totally, just where ovaled) with a wire welder and then start die grinding back till we the new pin to fit good. Other wise you could bore the holes bigger to fit a bushing and then weld them in. This would be nice because as time goes on if you need to do it again all you would have to do is remove the bushing and put a new one in.
F-I-T
03-17-2005 07:37:22
 Re: How to fix ovalized holes in #45 loader in reply to JDBert, 03-17-2005 07:27:00
I think JDBert has it right. Plus, you can install a bushing as if it were a full-length pipe so that you have no alignment problems. You might want to put a zerk on the bushing so that you can grease it well and aid in pin removal. That's one of the problems that I have on my 45 W right now. One of the rear lift cylinder mounting pins just will not come free, but I have not tried very hard either.....
Frank
Dave in CT
03-17-2005 09:25:19
 Re: How to fix ovalized holes in #45 loader in reply to F-I-T, 03-17-2005 07:37:22
Say F-I-T, while we're on the subject, what're your recommendations for getting the seals and O-rings to rebuild the cylinders? I would imagine John Deere just has a kit but I don't like paying John Deere prices, especially if it's on items that are standard sizes that can be ordered from a seal house. I've an owner's manual but not an exploded parts view. Do you know the sizes of the rebuild elements on the cylinders?
F-I-T
03-17-2005 10:41:30
 Re: How to fix ovalized holes in #45 loader in reply to Dave in CT, 03-17-2005 09:25:19
No, I don't have any detailed info. The last kit I bought from Deere because I needed the large entry bushing. The cylinder is fairly standard in dimensions, so it should not be hard to find the parts at a hydraulic shop.
Mine has power tilt, too, so when I rebuilt the bucket cylinders, I just ordered the seals and o-rings piece meal from JD. I doubt I had $20 in each cylinder that way.
Frank
Gerald J.
03-17-2005 09:37:46
Look to Baum Hydraulics at Omaha for cylinder seals. They do have a web page.
Gerald J.
Dave in CT
03-17-2005 09:06:56
Yeah, getting one of my rear pins out was a bear. Daily soaking with penetrating oil for about a week. Even then, with a good two-arm puller and a bracket made to hold the ends, it took a great deal of force to get it to break free. When it went it sounded like a rifle shot. The other was a piece of cake. I certainly wasn't going to put new ones back in without some anti-sieze but I like your full-length, grease-zerked bushing idea. Thanks for the posts guys.
