Hello everyone,I am slowly progressing on my 520LP as I got most of my engine back from the shop today. I still have to get the head done with crack repair and then surfacing it. Damn the luck, the ring spacers that I ordered from hastings are not quite right. They are about 1/16" larger O.D. than the piston..... this could be a problem. I think I'll have to give hastings a call monday (and pay like $8 shipping again). Oh well, at least this is fairly minor. I've got my transmission pretty much assembled now. The rear end is completely redone with new bearings and seals...nice paint too. It kinda looks wierd now with new green paint and old faded yellow hubs/rims with old tires (that can get done after the tractor is completely together). I am debating on what exactly to do with painting the transmission case.... Do I put it all together(reduction cover, crank, ect) and then paint or do I try to paint some now before installing the reduction cover and just try not to get paint on internal surfaces?? Also, does anyone have any good recommendations for cleaning that nasty caked grease off of transmission area parts....the hi-pressure washer doesn't do all that well. I can see it being difficult to get the transmission case, front frame, and reduction cover clean from oil so the paint will adhere to it. But, not to the original reason for my post.... I was at the local auto parts store today and noticed the high temperature paint for engines. There is some for 500 deg. and some for up to 1200 deg. If I sand blasted my exhaust manifold and exhaust pipe/muffler could I paint it all black?? I read the can and it really didn't indicate as with what to prime it with. Mine being LP I wonder if it gets hotter than 1200 deg Fahrenheit and will peel or burn the paint. If it works it would sure be nice for the manifold not to get that surface rust. Just wondering if anyone has had luck with hi temp paint. Too bad that JD doesn't produce a good hi temp green paint. (I would be in luck if I were restoring a Farmall M with red hi-temp paint being available) I am taking pictures of the restoration so I will be able to post sometime in the future. I am just swamped with school, my internship, and trying to help my dad with farmwork. Ag club, Collegiate Farm Bureau, and Delta Tau Alpha (ag honor society) keep me very busy. The old green gal in dad's nice shop isn't getting all of the attention that she did when I wasn't so busy. Thanks for reading my ramblings and for the helpful advice (hopefully). Tyler in Missouri
