How much fuel will a 4020 burn
Toby
03-16-2005 17:37:50
I bought a cheap 4020 to speculate on but it runs great. I thought about putting a disc mower on it this summer. I do wonder with fuel prices like they are how much extra will it burn vs a TS100 NH. I am hooked on 4020s.
no.2
03-17-2005 05:22:51
 Re: How much fuel will a 4020 burn in reply to Toby, 03-16-2005 17:37:50
We have a 4020 and a NH TS90 4WD. I like to mow with the 4020, my son likes the TS90. We have a New Holland 3-pt disc mower and I can see the cutter bar a lot better from the seat of the 4020. Fuel wise I don"t think there is much difference, neither uses that much fuel running the mower. The controls are a lot handier on the NH.
Gerald J.
03-16-2005 20:11:06
Depends on whether its gas or diesel. Before tuning my 4020 gas burned and average of 12 gallons an hour. (400 gallons in 33 hours). After tuning its down to about 8 gallons per hour average, varying from full throttle plowing to lightly loaded mowing or running a loader.
The diesel 4020 has a better reputation. The gas as I recall was rated at 7.93 hp-hr /gallon while the diesel was rated about 13 hp-hr / gallon, a whole lot better.
The going price for the gas is so much better that the price difference will pay for years of gasoline.
Gerald J.
G/MAN
03-17-2005 07:41:38
 Re: How much fuel will a 4020 burn in reply to Gerald J., 03-16-2005 20:11:06
Installing a Pertroniz electronic ignition set-up may gain you a little more fuel economy yet. Plus aid in throttle response and starting. Not terribly expensive and pretty easy to install. Just make sure you get a positive ground or negative ground set-up depending on your electrical system.
Gerald J.
03-17-2005 09:48:15
 Re: Electronic ignition in reply to G/MAN, 03-17-2005 07:41:38
My experiences with electronic ignitions over the eons have been that they didn't do much for fuel consumption, but they didn't add to reliability either because of the use of many parts. They only have a chance at greater fuel economy if the mixtures are leaned at the same time and the hotter or repeated sparks make sure the lean mixtures burn each stroke. Lean burning can be hard on exhaust valves.
The 4020 suffers from some fundamental gas induction system flaws that are not cured by electronic ignition.
First it has no ignition advance for part throttle. That can have a 20% change in fuel consumption according to some gas engine design text books. Been known since the 1930s.
Second it has that yard long intake manifold. Its unlikely to be able to get the same mixture for the end cylinders as for the center cylinders, so to save running the end cylinders too lean, the center cylinders have to run rich. That comes from condensation in the long manifold runs.
I have it to the point that even warm it starts better with choking. I believe that is sufficiently lean.
I'm wondering about transfering the injection system from a Taurus FFV to get both intake port fuel injection and computer controlled ignition as a way to significantly improve its economy and to allow using alternative fuels like E85.
One thing it doesn't like (and I can't apply manifold heat comfortably) is 10% gasohol. Maybe I need to fix the manifold heat or use it only in hot weather.
Gerald J.
G/MAN
03-17-2005 10:32:47
 Re: Electronic ignition in reply to Gerald J., 03-17-2005 09:48:15
I said "may" and "a little". No promises. However, any time you get a hotter spark, you get a better fuel burn. A better burn on the fuel that's already existent in the cylinder results in more power being created from the same amount of fuel, and therefore better economy. Whether or not it will be measurable is another story. They DO aid in starting and throttle response, and I speak from the experience having installed at least two of them on spark-ignition New Gens.
msb
03-16-2005 20:49:18
According to Deere engineers a 4020 gas was designed to burn 9 gallons per hout under rated load.So you are doing pretty good Gerald.My old 4020 diesel uses about 6-7 gallons per hour depending on how hard it is worked.Less if throttled back under light loads.
