730 DIESEL VALUE SPRING
Scotty
03-16-2005 16:49:58
I have a 730D that had a stuck value and in the process of freeing up the value I took the value spring off . Welllll.....I got the spring off with a pry bar , useing it as a lever and prying down on each side of the retainer until the keepers popped out, the value stayed still because it was stuck in the head. So now it's time to put the sping back and all the spring tools I have are for automotive or small engines and the ole pry bar won't work either. Makes Putting them keepers back in a nightmare! I have the other type tool to use when you have the head off but where the head is still on the engine and the spring is so tall nothing I have will work .Any body got any ideals ?????...Thanks for your time and help...Scotty
F-I-T
03-16-2005 19:54:38
 Re: 730 DIESEL VALUE SPRING in reply to Scotty, 03-16-2005 16:49:58
third party image
Scotty:
Like Mike said, on a diesel, TDC should leave very little clearance for the valve to move inward. As to the tools to use for the spring compression, I use a small engine valve spring compressor which will fit the spring on the head side only. They only cost about $20.00 and I use mine all the time to compress all sorts of springs. The diesel springs are not all that stiff, and I think a compressor like that might do the job.
Here's a link:
Frank
Mike M
03-17-2005 05:27:34
 Re: 730 DIESEL VALUE SPRING in reply to F-I-T, 03-16-2005 19:54:38
I have one of those tools. I think they are mainly for small engines and I don't think they will open up large enough around the big 2 cyl. springs. Check some of the local engine shops they may loan you one to try before you buy one and find out it won't work.
F-I-T
03-17-2005 06:15:50
 Re: 730 DIESEL VALUE SPRING in reply to Mike M, 03-17-2005 05:27:34
I used this one on my 70 Diesel. THat's why I recommended it.
Mike M
03-17-2005 07:05:34
 Re: 730 DIESEL VALUE SPRING in reply to F-I-T, 03-17-2005 06:15:50
If you found one that opens up for that 70 I'm sure it is the same for a 730. That tool is just what he needs. I ordered one from NAPA that looks like yours but must be a smaller size.
Duane Larson
03-16-2005 17:23:01
Scotty,
The old JD way of removing/installing valve springs uses two rods (pushrods were suggested). Tie them together at one end, and then tie that end to another valve spring, and use both rods together as levers, pushing down on the valve keeper retainer evenly on each side of the valve. Have someone hold the valve out until the spring is compressed enough to allow the keepers to be installed. Then release the levers. As noted in the earlier post, safety glasses are required!!!
Mike M
03-16-2005 16:59:55
If you run the piston all the way to the top it should be pretty close to the valve to hold it from dropping into the engine isn't it ? I also wonder if it would be possible to compress that spring in a vice and then run wire through it may have to stay back from the end and wire it compressed. Then you could put it over the valve then cut the wires and pull them out. Just a thought ? Wear safety glasses incase it gets away from you.
Chuck in Ks.
03-17-2005 06:30:00
 Re: 730 DIESEL VALUE SPRING in reply to Mike M, 03-16-2005 16:59:55
Have you thought of using air pressure? In order to change a valve spring in a car while the head was still on the engine you had to put the piston at top dead center, then apply air pressure, don't remember how much, and the air would hold the valve in place while the spring was reinstalled.
Main drawback was getting the piston and crank lined up at top dead center, if not lined up straight the air would force the piston back down. We made an adapter that screwed into the spark plug hole that allowed an air hose to be attached. You should be able to make an adapter that will screw into the injector port.
Just my 2 cents if none of the other ideas work.
Good Luck
