70 gas and G pistons ?'s
JDBert
03-16-2005 08:03:40
I have 2 ?'s here. 1st will 730 lp pistons (standard bore) work in a 70 gas? All I should have to do is overbore it correct? Deere should have piston rings? Or is there somebody else to get rings from (cheaper maybe)? 2nd is there any difference between styled and unstyled "G" after market, high compression, overbore pistons?
430WLPG
03-16-2005 19:19:52
 Re: 70 gas and G pistons ?'s in reply to JDBert, 03-16-2005 08:03:40
No 730 pistons won't work,70 gas pistons are 5 7/8 just the allfuel 70's are 6 1/8 ,and the 730 pistons are 6" and the wrist pin is about 2 3/8 OD and the 70 wrist pin is 1 3/4 OD
shotgun
03-16-2005 17:16:03
70 gas is 61/8 720 lp is 6 cant say if 730 got bigger bore
Hooked
03-17-2005 06:19:08
 Re: 70 gas and G pistons ?'s in reply to shotgun, 03-16-2005 17:16:03
Sorry, but you are wrong. 70 gas pistons are 5-7/8 inches diameter. 70 power block pistons are 6-1/2".
Mike M
03-16-2005 17:11:26
I would say that the piston head design will be totally different between the 70 and the 730. I would recommend calling Hinrich's Repair. He sells lots of pistons and knows alot about them. He used to advertise in 2 cyl mag. and green mag. I'm sorry I don't have his number handy. If you can't find it post back and I'll dig around in the shop and see if I can find it.
