JD B Sticker Placement!!
5th Wheel
03-16-2005 05:15:43
Looking for a place that may show sticker placement on my 1941 B s/n (121XXX). Just got it finished and need to sticker it up!!!
Thanks
Bushogpapa
03-16-2005 05:53:07
 Re: JD B Sticker Placement!! in reply to 5th Wheel, 03-16-2005 05:15:43
You will need to check thouroughly, as earlier "B" JD's had two different positions for the transfer...The "Later" ones had it moved more toward the front as I recall.. You will have to check, but I think yours will be more centered on the hood..
5th Wheel
03-16-2005 05:58:07
 Re: JD B Sticker Placement!! in reply to Bushogpapa, 03-16-2005 05:53:07
I don't think my B had the "B" on each side of the grill did it. I was told, however that there should be a "B" on the seat pedestal???
yooperdeere
03-16-2005 07:35:49
 Re: JD B Sticker Placement!! in reply to 5th Wheel, 03-16-2005 05:58:07
Since yours is a 41 yes the B should be on the seat pedestal. It should be a decal reading Model-B and should be placed so you can read it standing on the pulley side of the tractor. The later Bs (47-52) had the B on the grill sides. For the right decals for your tractor call Jordes Decals....they will get you the exact decals your tractor had when it left the factory.
old bones
03-17-2005 18:56:15
 Re: JD B Sticker Placement!! in reply to yooperdeere, 03-16-2005 07:35:49
he'll not only get the right decals, but he'll tell you exactly where each one is supposed to go.
for what it's worth, forget the mylar decals. spend a few bucks more and get the precision cut vinyl. he'll tell you that, also. the man knows his stuff.
