fan shaft bearing and bevel gear.
Joe McGinnis
03-15-2005 20:31:02
Am working on a JD B serial # above 201 000. Have not been able to get the bevel gear off so that I can replace the bearing. I have removed the snap ring but feel that I am still missing some thing-- is there another snap ring? Sure would appreciate any help or ideas. Thanks in advance and God bless. JM
John T
03-16-2005 06:22:21
 Re: fan shaft bearing and bevel gear. in reply to Joe McGinnis, 03-15-2005 20:31:02
Joe, about the only way we get those (its press fit as Mike told ya) to move are to chuck up behind the gear and use a hydraulic press centered on the shaft to push it out of the gear. A gear puller may not be strong enough and can be hard to keep centered and pulling straight out. Do a good job of chucking up and centering cuz them are one tight of a press fit.
John T
Mike M
03-16-2005 04:41:56
Those gears are also a press fit on the shaft. You will need a bearing separator(cheese cutter)and a gear puller or better yet a press.
