4010 hydraulic problem
higbee
03-15-2005 11:49:37
I have a loader on a 4010. I have been picking up lots of trash from the brakes in the pickup acreen and filter. It all but stopped working for 2-3 days, then worked fine for about a month. The pump is just not pumping a good quantity of oil. Where is my blockage? Thanks.
Bob
03-15-2005 12:13:06
 Re: 4010 hydraulic problem in reply to higbee, 03-15-2005 11:49:37
Have you replaced the brakes and flushed the system? Continuing to run it with failed brakes will just cost more $$$$ in the end.
There is a screen up front, in the stroke control valve on the front of the main pump. If this is clogged, the main pump will not function properly.
