4020 hydraulic problem / question
Jason Z in MO
03-15-2005 09:03:52
I have an 1965 4020 with a loader connected to the factory valves.
With no weight on the loader, the slow and fast positions on the valves work properly. When I try to pick something heavy up in the slow position it will take the slack out of the chain but won't pick the weight. When I open the valve to the fast position it will lift the load. This alone tells me there is a low pressure problem. But now that the system is bearing the weight it will move up in the slow position just fine.
Any ideas what might be wrong? Is this still a pressure problem?
The valves do need to be rebuilt because when the tractor is shut down the loader settles to the ground. (as well as the 3-point)
Thanks for any advice,
Jason
darrel Ragoonath
03-24-2005 23:57:33
 john deere loader 466E in reply to Jason Z in MO, 03-15-2005 09:03:52
I am not sure how to bleed the brakes. The brakes is hydralic but no master cylinder. I do not have a techical manuel so i need your assistance. I am currently stationed in iraq and i need some help. Thanks in advance
thejdman01
03-15-2005 12:55:41
 Re: 4020 hydraulic problem / question in reply to Jason Z in MO, 03-15-2005 09:03:52
i thinkyou are using tuerms incorrectly not picking jsut trying to clear things up. the remotes are on the back which is what your hoses are hooked to. the valve bodies are under the hood as your sitting on the seat towards the left side. i would say you need to rebuild the valves under the hood. make sure not to twist those lines off. 1 line (connects between your legs there is a union) from the valve body to between your legs were 80 dollars for the steel line. heat and quench work pb blaster in. kroil much better but some lack it. i would recommend sending the vave bodies out to get rebuilt as theres adjustment and a plate for adustment (i made one not that hard to make). its not hard just depending on your ability and local friendlieness of the jd dealer wheather or not you want to tackle it or not. i from the sounds (although hard not being there or hooking a guage set up) would recommend rebuilding seals, needles etc in the valve. one test i would try is to lift the bucket shoulder chest high with the bucket tipped down hook some weight up to itand try rolling the bucket back. there are 2 seperate valve bodies and 2 seperate remotes for the up and down and the tilt. if you have a problem with tilt then that narrows down which valve body is giving you problems. also try switching hoses in remotes. if the problem moves when you switch hoses in remote then you know too. the problem should stay put if in remotes and valves.
Jason Z in MO
03-15-2005 13:44:59
 Re: 4020 hydraulic problem / question in reply to thejdman01, 03-15-2005 12:55:41
Thanks for the test suggestions. I do know both circuits will settle after the tractor is shut down. Actually, the #2 valve (remote on the left and left control lever) will slowly creep while the tractor is running. At least, from time to time when running around I have to squirt a little oil into that cylinder to curl the bucket back up. This is even without a load. On this loader to curl the bucket extends the cylinder.
I understand what you mean about the remotes. I hope I didn't confuse anyone. As I understand the system, the remotes are just the ports. As you point out the valve bodies are under the hood in front of the dash. A couple of cube shaped blocks.
The term SCV which was used on generation II tractors and incorperated the valve and remote into the same assemblies. Is that correct? I did use that term incorrectly ealier.
Thanks for your help and suggestions!
Bob
03-15-2005 09:19:03
You state "The valves do need to be rebuilt". That is PROBABLY true, however, there's more going on in those valves than you realize. The settling loader may be a symptom of a damaged poppet valve or seat, or it may be caused by bad seals in the loader cylinders.
The 4020 factory valves use "poppet" valves instead of the spool valves typically used in other hydraulic valves.
If the are either damaged, or out of adjustment, it would explain your problems.
There are 4 adjustment screws inside each valve body that control the timing of the poppet valves being opened by cams inside the valve body, operated by the hand lever.
It sounds as if one or more of those adjustment is "off". They need to be set by someone who knows what they're doing, and a special "jig" is needed, and the adjustments are made using a dial indicator.
Jason Z in MO
03-15-2005 09:32:48
 Re: 4020 hydraulic problem / question in reply to Bob, 03-15-2005 09:19:03
Bob,
Thanks for the quick response! The settling problem is within the tractor systems; I believe. I use this tractor with a 15' cutter which requires the hydraulic valves. I remove the bucket to shed the weight and diconnect the loader lines from the SCV's. I have had the loader disconnected like this for literally months and the cylinders don't move a bit.
Another symptom I didn't mention was there is a buzzing sound coming from the hydraulic system. Noticable but not overbearing. I think its coming from the large line on the left side of the tractor, behind the frame and under the clutch pedal. When the system is moving oil; 3-point or loader, the sound is gone. Maybe thats not a big deal; the steel line vibrating with low flow.
Bob
03-15-2005 12:17:12
 Re: 4020 hydraulic problem / question in reply to Jason Z in MO, 03-15-2005 09:32:48
As to the noise, I can't tell you for sure. These systems DO make quite a bit of line noise, and it's hard to tell over the 'net if your's is normal or not.
If one or more of the 8 pistons in the main pump is not functioning, noise levels may go up. There is a chance of a broken spring on a piston, or valve trouble.
If you can get someone with a flo-rater to check out the system, a problem with the pump will show up as lack of rated flow, and excessive pressure pulsation.
