How to time 1020?
Rudebob
03-14-2005 14:53:59
I have a 1020 that has"t ran for seven years. Where is TDC? It has a "S" that"s close. Have done complete tune-up, new coil, cap, rotor, pts., condesor, plugs, wires. Needs wiring harness & switch will came after it startes. It has good spark, but to get dist. turned right so it will starte, any help would be appreciated. Thanks.
jdemaris
03-14-2005 19:36:19
 Re: How to time 1020? in reply to Rudebob, 03-14-2005 14:53:59
The "S" mark on that 135 c.i. engine is the advanced timing mark, i.e. 28 degrees before top dead center. That's the mark you want to see at full RPM when using a timing light. There is also a TDC mark on the flywheel - that is the mark to use when static timing the engine.
Rudebob
03-17-2005 10:15:55
 Re: How to time 1020? in reply to jdemaris, 03-14-2005 19:36:19
Hi Guys, Thought I would let you know I got the "1020" running. Many Thanks, Rudebob.
Dave Brennan
03-15-2005 06:21:32
I like it here, always learning something. On older equipment it would have been for spark, The engineers that build this newer stuff had different ideas than the old timers. I see your point. Dave!
jdemaris
03-15-2005 06:31:44
 Re: How to time 1020? in reply to Dave Brennan, 03-15-2005 06:21:32
Yeah, well it does stand for "spark", just not the specific spark you're looking for. It's spark as high speed, and I guess your looking for spark at low speed, i.e. "unadvanced."
F-I-T
03-14-2005 15:18:56
RB:
The BEST method of finding TDC on the compression stroke is to put your finger tip in the sparkplug hole of #1 and rotate the crank pulley with a wrench, or grab the fan blade and turn with your hand. If the other plugs are out, it will turn pretty easily.
When the air starts squirting out past your fingertip, your are coming up on #1, comnpression. Now look into the hole with your small flashlight and you will be able to see the piston coming up and you will be able to stop it at TDC or VERY close to it. Now look at your crank pulley and the manufacturer's timing mark will most likely be evident.
Frank
1020gas
03-14-2005 15:47:02
 Re: How to time 1020? in reply to F-I-T, 03-14-2005 15:18:56
quoting from the service manual:
Follow F-I-T's instructions. When you feel the compression on #1 continue turning until the "S" mark on the pulley lines up with the mark on the engine casing.
remove coil-to-distributor high tension wire from distributor and place terminal end 1/8 inch from grounded part of engine. Turn the key switch on.
Turn the rotor counter clockwise as far as possible. Hold rotor in this position and rotate distributor body slowly until the points are just beginning to open. This is indicated by a spark between the high tension wire and ground.
Tighten it up
After you get it where it starts put a timing light on it. Run engine at 2500 RPM and line up the "S" mark on the crankshaft with with the mark on the engine casing
Peter D. S. NY
08-10-2006 12:22:22
 Re: How to time 1020? in reply to 1020gas, 03-14-2005 15:47:02
Wow, this site is great, thankyou everyone!
I didn't even have to ask, and I found my answers here...
Yesterday I put in new points, condenser, plugs, rotor, cap and wires...It started right up, and died.
Couldn't think of what I had done wrong. Your FIT instructions really helped. Set it up, and it started right up and ran. Then put the timing light on, and it was spot on!
Phew.
Now to add an inline filter without cutting my metal fuel lines.
Dave Brennan
03-14-2005 15:42:25
If you found an "S" that should be for spark. When number one is on the compresion stroke and you have the "S" in the "window" this is when the points should be opening with the rotor pointing to number one on the cap. Wire the fireing order from there and it should run.
