'50 Model B losing power......
Jeffro1
03-14-2005 12:31:00
I ran my B pretty long and hard about a week ago. It ran great all day long. Yesterday I went to do a little light plowing and the thing was really dragging. It would barely pull itself out of the shed in reverse. It was difficult to even get it move without choking off completely. I tried a little plowing and could not do it. Even raising the plow seemed too much for the engine-tried to choke itself off whenever any load was applied. I tried some carb adjustments-no help. Checked the plugs and they looked O.K. I am wondering what could cause such a big decline in such a short time. What could have changed? Has anyone had a similar experience? The engine sounds the same, just chokes down really easily? Could this be a stuck valve? How could I tell? What about a mag problem? Would could the carb do which would cause it to act so odd? The only other thing I can think of is that a small puff or two of grey smoke comes out of the stack when it tries to choke down. I am stumped-where should I start?
-Thanks
-Jeffro
Jake
03-14-2005 21:29:50
 Re: '50 Model B losing power...... in reply to Jeffro1, 03-14-2005 12:31:00
Maybe something built a nest in the air intake while it was parked in the shed?
mattd
03-14-2005 19:23:39
i had the same probelm a while ago on my trailer queen B. found that there was some crud in the gas tank. cleaned it out and runs great again. make sure you have good gas flow by loosening the drain on bottom of carb and make sure it flows good for 30 seconds. if not, start checking for crud in tank, lines, carb.
matt
Dave Brennan
03-14-2005 14:05:31
Check to see if the float is sticking or sunk from a pin hole in it.
