Power steering pump
JDMAN60
03-14-2005 12:14:03
Well part of the restoration on my 60 was to replace the seals in the power steering pump. I have the tractor back together enough that I have run the engine for about 20 minutes to warm it up and my pump still leaks badly. It does not seem to be leaking around the shaft but where the three machined surfaces of the pump mate together. I checked the bolts and tightened them up some more but still leaking even without the engine being started for about three weeks. Am I missing something the parts book shows no gaskets for the pump so What should I do? Thanks for your help Jdman60
Larry in WNY
03-15-2005 09:48:41
 Re: Power steering pump in reply to JDMAN60, 03-14-2005 12:14:03
Make sure all surfaces are flat and clean. Use a very small amount of sealer called HondaBond (from the Honda dealer) between each piece. This is what some of the expert restorers use. I used Permatex, but when I redo my pump again I'm using HondaBond. If you have the pump apart why not change the bushings and bearing? 4 seals are needed each facing back to back with the inside lip towards the oil and outside lip towards air.
JDMAN60
03-15-2005 03:28:51
Many thanks to you all I hate to do it but I will take the pump back off and try some sealer.
55 50
03-14-2005 18:50:53
Try Permatex aviation form-a-gasket. Also know as No. 2 Permatex. Use a very light coat of it.
Dave Brennan
03-14-2005 14:11:53
John Deere makes a sealer that comes in a bottle. It is translucent red in color. I've used it on items such as this and have had good luck with it.
Mike M
03-14-2005 12:38:29
You need to put some kinda sealer on those sections. After I make sure they are clean and flat/burr free I have found that a very light coating on each side of the center section of silicone sealer of the ultra type works great.
Randy Stoudt
03-14-2005 12:32:12
Try flat filing or better yet use a fine abrasive stone to remove any nicks, burrs, or high spots that will prevent the machined surfaces from sealing. You can also use fine emery cloth laying on a known flat surface and polish.
F-I-T
03-14-2005 12:18:59
JMan60:
Did you use any sealant between the sections? Also, it helps to "wring" or lap the flat sides of the pump sections until they are flat. I used gasker shellac between the sections and had no leaking at all on my 70D.
Sound like you might have to remove the pump for another R&R.
Frank
