B manifold bolts.........
JDK
03-14-2005 11:23:33
Anyone out there know if there is an alternative to using the factory made studs for the exhaust manifold?
I got a B sn-287xxx. Forty bucks for 4 studs gets a guy looking around for something different.
I havent found anywhere else I can buy these either. I'm not complaining about the quality of Deeres parts, as these have lasted over 50 years. If their parts are the best that can go on my tractor, then thats what I'll have to do. Thanks.
Harley in PA
03-20-2005 15:04:35
 Re: B manifold bolts......... in reply to JDK, 03-14-2005 11:23:33
I got some for mine from McMaster Carr.
Cost me about 12 bucks I think.
Harley
donwisc
03-14-2005 12:12:53
Unless you are super critical about going back to original, use at least grade 5 bolts, you can cut to suit or use washers.
JD @ Antique Acres
03-14-2005 12:17:31
 Re: B manifold bolts......... in reply to donwisc, 03-14-2005 12:12:53
I am not 100% but aren't the manifold bolts, (block end) tapered threads? Thus the high price from Deere. Thought I saw this some where.
Dave Brennan
03-14-2005 14:23:51
 Re: B manifold bolts......... in reply to JD @ Antique Acres, 03-14-2005 12:17:31
Everyone I ever fixed looked like standard treads to me. when you replace them be sure to use sealer on the end that goes in the block, otherwise they sometimes weep coolant. I' ve had some in my shop that have had a good grade of treaded rod someone used for new studs. I'm not crazy about using treaded rod but it worked on those tractors.
Deeredale
03-14-2005 20:07:43
 Re: B manifold bolts......... in reply to Dave Brennan, 03-14-2005 14:23:51
We have used bolts many times. It is usually not due to price but the only thing we had at the time to complete the job. As one earlier said be sure to seal the threads with something high temp. rated or you will loose coolant.
