Adjusting 4230 rear wheels
R. John Johnson
03-14-2005 08:26:53
My new to me 4230 is still at my cousin's shop. The rear wheels needed to be moved out so that I could use it to bale. One side came fine. The other side is a problem. He has tried all the tricks. He did not use heat for fear of damaging the axle temper or the seal and bearings on the axle shaft. The joint has been soaked daily with penetraing oil. Tried the 20 pound sledge on the end of the axle. Currently there is a 20 ton porta power pushing on the axle and grade 8 bolts pushing on the wedges. Tried a punch on the wedges with all that pressure. Already broke one set of grade 8 bolts.
Since it will be a while till I will be baling, Went down close to 0 Farenheit last night, I have time. Currently The tractor is going to sit outside for a while. The jack bolts are still tight and it will get sprayed with penetrating oil daily.
If all else fails we will have to remove the tire, remove the final drive assembly, dissasemble and have the axle/hub taken to a shop with a BIG press.
Any other ideas? I'd rather not resort to the final option of the BIG press.
John
R. John Johnson
03-14-2005 14:17:04
 Re: Adjusting 4230 rear wheels in reply to R. John Johnson, 03-14-2005 08:26:53
Just talked to my cousin. He got it to move. She'll be ready to roll by this evening. Just wish I could dare leave the calving cows long enough to drive her home.
John
JD Jerry
03-14-2005 08:59:07
I have driven the tractors around the yard with the bolts loose. Has worked evey time.
