4430 rear end update
HA in Oh
03-14-2005 00:24:35
I've heard that the early 4430's had rear end problems and had to be updated. When looking at one is there any way knowing that it has been up dated? A jockey has one that I'm interested in and I've never been around 4430's. Thanks for any help.
msb
03-14-2005 19:27:33
 Re: 4430 rear end update in reply to HA in Oh, 03-14-2005 00:24:35
Often times you can see that the axle housing gaskets have been changed and will have no paint on the gaskets.
buickanddeere
03-14-2005 11:02:12
Wasn't there an axle dia increase with the later tractors? Or was that extra dia on tractors ordered with the extra long axles for duals? Did this tractor do a lot of pto work or pulling heavy draft loads in the lower gears ( not good). Worse yet if somebody tried to make a 4630 out of it by tinkering with the injection pump.
jddriver
03-14-2005 09:54:08
The rearend is weak on the pre 75 models.The diff needs to be updated to a3 pin pinion.The early ones had left over 4020 parts in them.The power shift unit inthe quad range needs to be updated to a6 bolt unit and the supply pump in the trans should be upgraded to a4440 pump Steve
ET
03-14-2005 06:07:40
Outboard rear axel bearings were a bigger problem than the rear end.
