4020/transmission clutch
Glen Anderson
03-13-2005 19:34:06
The trans. clutch on our tractor started slipping recently, further investigation revealed - no more free-travel adjustment - time for a clutch right?
Since we are in bind for a tractor I thought I'd try cheating a bit. I opened the clutch inspection window and noticed the fingers for the trans. clutch pressure plate were tight. I figured that if I loosened the fingers off a bit it would let the pressure plate clamp the clutch disc. hopefully giving me a few more hours of use before the dreaded split.
I found a small piece of flatbar 1/8" (I think)
and used it as a gauge to set the fingers(I placed it between the fingers and the release bearing)
After completing my MacGuyver manouver I hooked onto our cultivator and took the tractor for a test drive. I was able to stall the engine with the load of the implement or spin the tires depending on ground conditions with no sign of clutch slippage.
My question is, has anyone tried this before and if so how long will this last?
Mike M
03-14-2005 05:37:24
 Re: 4020/transmission clutch in reply to Glen Anderson, 03-13-2005 19:34:06
I did that on a IH tractor once years ago it may still be going ? I saved the guy a ton of money !
JimKS
03-13-2005 23:41:16
I know a guy who has been running his 4010 that way for a couple years. It's a loader tractor and he uses it almost every day.
Bob
03-13-2005 21:30:14
Who knows, the last guy to work on the clutch might not have set up the fingers properly, or if they did, you are probably about ready to rip up the flywheel and pressure plate with the lining rivets.
It might go a day, or hundreds of hours. It also depends upon whether it slipped enough to get the pressure plate springs hot enough to weaken them.
Glen Anderson
03-14-2005 08:03:04
 Re: 4020/transmission clutch in reply to Bob, 03-13-2005 21:30:14
Thanx for the replies Mike, Jim, & Bob. I hear ya on the rivets tearing up the flywheel and pressure plate. I was kind banking on the last guy having set the fingers a little too high.
I've never tackled a clutch replacement on one of these outfits before, but after reading our I&T shop manual and JD shop manual it wasn't clear to me anywhere about whether or not the clutch fingers would have play after the heigth was set. I would think they should, otherwise the pressure plate would be held partially disengaged causing the clutch to slip.
I'm assuming if the finger heigth is set right(to specs with the proper guage) that lining thickness is taken into account so there is a buffer zone between the time of clutch slippage(when the fingers get tight, holding the pressure plate partially disengaged)and when the clutch rivets start to damage the flywheel.
Is this correct? Bob, how much clutch material would be left before the rivets start to contact assuming the fingers were set right at the last clutch job?
