A Model flywheel and end play
Dave in SV
03-13-2005 16:46:55
The I&T JD-4 manual, paragraph 110, talks about flywheel R&R. It says that the crankshaft end play is determined by flywheel position on the shaft. Where do I measure this end play when I reinstall the flywheel?
Also, the same paragraph says that the ring gear teeth beveled edge is supposed to be toward the crankcase... mine is away from the case. Is this a big deal, and should I do something about it?
Pat Browning
03-14-2005 16:15:07
 Re: A Model flywheel and end play in reply to Dave in SV, 03-13-2005 16:46:55
If you follow John T's procedure, you can't go wrong. The less end play, the better. Bring that flywheel right on in to home with a second person on the crank's other end to push (or drive) against, then tighten her down! Just go for almost NO endplay. (PatB)
Dave in SV
03-14-2005 17:52:32
 Re: A Model flywheel and end play in reply to Pat Browning, 03-14-2005 16:15:07
Thanks for the info, Pat.
Per the parts manual, there doesn't appear to be any shim or washer between the flywheel hub and whatever stationary surface it is snugged up close to. Is that true, or am I missing something?
Pat Browning
03-15-2005 16:14:57
 Re: A Model flywheel and end play in reply to Dave in SV, 03-14-2005 17:52:32
No shim -- just snug the flywheel up to the ring and you will be fine. (PatB)
John T
03-13-2005 17:27:53
Dave, Im more into electrical stuff, but for what its worth, heres how I set them. We loosen the flywheel and have one guy hold a sledge tight up against the opposite sides big clutch drive disk end bolt as a guy on the flywheel side uses an oak block n a hammer to drive her in to her milk just about as far as she will go. I think the spec is like 0.005 to 0.015 measured between the flywheels inner center to where it bumps up against that D shaped seal n bearing housing on the tractors side behind/under the flywheel. Basically, when we can just barely tug in n out on the flywheel and feel just any slight movement at all, we stop.
Yes, the ring gear on the flywheel ought to bevel open/out on the starter side for the starter drive gear teeth to engage. If yours is on bass ackwards, you could heat the ring gear n remove it, reverse it, then re heat it n drive it back onto the flywheels outer circumference. Otherwise you would have to take a small grinder and chamfer grind each tooth to make that bevel.
John T Nordhoff in Indiana
I Bleed Green
03-13-2005 17:15:18
Go to page 4 of my picutres. Push the flywheel to the engine, set the dial indicator to 0, pull the flywheel out and look at the reading of the dial indicator.
fixerupper
03-13-2005 18:04:55
 Re: A Model flywheel and end play in reply to I Bleed Green, 03-13-2005 17:15:18
A good way to find crankshaft endplay is to engage the clutch and then while the clutch is engaged, pull back on the clutch lever so you start feeling resistance, but don't pull enough to disengage the clutch, this should push the crankshaft to the right. Then push the lever ahead as far as you can go and this should push the crankshaft to the left.If you have any end play at all you will see the flywheel move sideways a little bit as you rock the lever back and forth. You can stand on the ground beside the flywheel and reach across to the clutch lever to do this. Oh yes, the tractor should NOT be running when you do this.
I Bleed Green
03-13-2005 18:40:07
 Re: A Model flywheel and end play in reply to fixerupper, 03-13-2005 18:04:55
Man you do things the hard way, and sure not the right way!!!!! !!!!! !!!!
fixerupper
03-14-2005 19:10:06
 Re: A Model flywheel and end play in reply to I Bleed Green, 03-13-2005 18:40:07
I've done it this way for many years. You can climb on any waterloo two-popper and find out what the end play is real easy without removing stuff.
Dave Brennan
03-14-2005 03:56:34
I use a dial indicator and magnetic base to set the flywheel end play myself.
