420 with broke gear back up and runnin'
denjoe
03-13-2005 14:58:12
Well it was the cluster gear that had broken a tooth. Seems the lock pin that holds the pinion gear shaft in place came loose and got into it. Anyway, found the gear new for $300 bucks at Mid South Salvage 1-256-353-5661. I am posting their # because everyone else wanted up to $650 for the same gear. I will say I never want to take another one of those trannys apart again.
HAL
03-13-2005 16:19:06
 Re: 420 with broke gear back up and runnin' in reply to denjoe, 03-13-2005 14:58:12
Iam with you I just replaced the same gear in mine except on mine the jam nut off of the load and depth control spring came off and worked its way up into the oil passage way between the transmission and differential and was jammed and sticking through into the transmission so that the cluster gear was CHEWING on it, I need to take a picture and post it, It is hard to believe!
