G Governor won:t kick in
Ben.So.Tex
03-13-2005 11:29:28
I took my G out of the shop today to see how well it pulls, Hooked it up to a 12 ft disk harrow.It will pull but the governor does not want to load up, tractor will loose power. What could be the problem? This is the First time I have woorked is since I got it.Thanks Ben
Tyler from Utah
03-17-2005 09:17:24
 Re: G Governor won:t kick in in reply to Ben.So.Tex, 03-13-2005 11:29:28
Are Allis did the same thing ended up to be that the governer wasent getting any oil, the supply line was pluged and we replaced it and worked fine! good luck! - Tyler
Garland(Gman)
03-13-2005 16:25:59
Ben sounds like you could have an adjustment problem,take cotter key out of rod going to the govoner spring pull throttle wide open and the grab rod and pull throttle on carb. the rod and the spring should be half a hole off,the throttle rod has an adjustment to attain this hope this helps Gman
Ben.So.Tex
03-13-2005 16:59:23
 Re: G Governor won:t kick in in reply to Garland(Gman), 03-13-2005 16:25:59
Thanks GMAM & Bob.. I did do some ajusting on the linkage rod so I might be the problem...And Bob it was blowing alittle black smoke when it had a load. So I am thinking both of you may have hit the nail on the head.. I will readjust and see what happen later this week..Thanks Ben
Bob
03-13-2005 16:07:10
Often, "governor will not open up" problems turn out to be fuel supply or carburetor problems.
