620 LPG starting tips
old hank
03-13-2005 11:18:47
Have just repaird clutch and starter on 620 lpg.
Tractor had not been started for about ten years.
Have fresh fuel, good spark and compression.
Cant get her to start.
Any tips apreciated.
730-LP
03-14-2005 21:46:30
 Re: 620 LPG starting tips in reply to old hank, 03-13-2005 11:18:47
Most common problems have been answered below but John Deere has a manuel on LP engines that is very helpful'I don't have the # of it here but if you need it post back and I'll get it and post back.
Garland(Gman)
03-13-2005 16:31:45
Hank there is a vent hole next to the priming plunger on the vaporizer Mud Dobbers love to nest in there,also the fuel strainer will gum up take apart and clean. Gman
shotgun
03-13-2005 16:11:36
70 wont run with oil bath off tryed 3 vaperizers till i got one that would work
Tom in Mo.
03-13-2005 16:05:55
Many things to look at here. The fuel has to pass through the fuel filter first which has an electric solenoid on it. If the solenoid is working and the fuel filter is clear, then the convertor is probably in need of rebuilding. I have rebuilt many of these Century models and usually they are just gummed up or dried up. One convertor rebuilt was clogged up with a black tar from the fuel. They are pretty simple to rebuild and rebuild kits are available from your local and cooperative LP supplier. They are pricey around 50 to 60 bucks. When rebuilding be sure to follow the directions on setting the diaphram clearance and make sure the high pressure to diaphram valve is totally free to move without restriction. After the rebuild, if it still doesn"t start I would rebuild the carb. This is real easy and Deere still carries the rebuild kit. Check the gap on the plugs.
Too much LP or too little LP will not allow it to start. Good luck and keep us posted. Tom
Ben.So.Tex
03-13-2005 11:47:10
I maybe had the same problem with my 730lp. 1st check for spark, Then I poured alittle gasoline down the breather stack and she fired up.I had to keep nursing it with gas to keep it running, that also told me that the regulator was not working.I rebuilt it and it has been running fine for the last 4 yrs...NOTE ..The LP tractor has to have the oil bath on the air cleaner for it to run, This help it pull vaucum of the regulator it will not run with out it. At least my 720lpg & 730lpg won't...Good luck Ben
Magoo
03-15-2005 13:23:58
 Re: 620 LPG starting tips in reply to Ben.So.Tex, 03-13-2005 11:47:10
When you turn on the ignition switch, you should hear a click from the fuel valve at the strainer. There is a primer button on the inside of the converter to purge/enrich the system to start.
Magoo
