4010 frontend ???
gwece
03-13-2005 09:13:35
third party image
Can anyone tell me what kind of front end this is on my JD 4010 Diesel? I lost a bearing dust cap and need to replace it. Deere Dealer tells me this probably isn't a Deere front end (or at least the hubs aren't). Hubs definately are not like the ones in the Deere online parts sheet. Thanks!
MisterShh
03-14-2005 19:04:30
 Re: 4010 frontend ??? in reply to gwece, 03-13-2005 09:13:35
Looks like a R49839 hub. Dust cap would be a R50992.
thurlow
03-14-2005 08:18:39
Hubs look exactly like what's on a 4430.....
gwece
03-14-2005 05:17:53
Thanks to all of you for responding. It's good to know at least the front end is JD and not aftermarket, even if the hubs are not. I will try to find a casting number on the hubs and/or match up the other dust cover at Deere or local auto parts store.
Thanks Again! gwece
Tx Jim
03-14-2005 04:31:50
 30 series hubs???????? in reply to gwece, 03-13-2005 09:13:35
gwece,they look like hubs off a 4030/4230 tractor.I don"t know if those hubs will fit a 4010 but I agree with others that the rest of frt. end looks factory.I also agree that if you can find a casting # on hub that would narrow it down fast.Tx Jim
R. John Johnson
03-13-2005 19:53:57
Is it possible that this is an aftermarket front end similar to the ones sold by A+I? They sell complete front ends and knee and spindle kits that fit the JD cast center. They were supposed to be built heavier than the factory original to stand up to loader use.
If a dust cap is all you need, is it possible to take the remaining one to an automotive parts store and have it matched?
Just thinking out loud.
John
Mike Aylward
03-13-2005 15:54:25
Gwece, you do have a John Deere wide front but I am speculating that either the hubs were purchased in the 70's to replace some that were damaged or the whole front end was through Whole Goods as an attachment. Those hubs are from a later Deere tractor as the other poster said. It is a Deere wide front through and through, just not quite as original as the front end the 4010 would have come with originally. Hope this helps. Mike
Bob
03-13-2005 15:31:33
If the hubs are Deere, from another application, there will almost certainly be a JD trademark, and a casting number cast into them, which may lead to their intended application.
If they are another brand of wagon hub or whatever, that happened to fit, there still will likely be a manufacturer's name and part number cast into them, if you clean them up and look closely.
JD wagon
03-13-2005 14:29:26
 JD wagon hubs in reply to gwece, 03-13-2005 09:13:35
Your hubs are from a john deere running gear.
matthies
03-13-2005 12:28:06
Those hubs maybe off of a later tractor like a 4030/4040 or 4230/4240. The 30 and 40 series tractors used drive in caps. Your Deere dealer should have known this. These are heavier hubs than the original 4020. chris
I Bleed Green
03-13-2005 09:52:50
Well the front end is a John Deere for sure, but the hubs are NOT right. If they are John Deere hubs, maybe they are from a wagon or something. I have a John Deere wide front end on my 4020. The hub caps have 3 bolts holding them on.
