3pt 4020
toby
03-13-2005 07:39:44
I bought a 4020 and it all seems to work. It seems that the 3pt is not raising all the way to the top. How can I tell if it is going to the end of the stroke or not.
Thanks
Toby
Mike M
03-13-2005 09:09:46
 Re: 3pt 4020 in reply to toby, 03-13-2005 07:39:44
I would think it would be the same way I check smaller tractors,just may need a helper. On smaller stuff I raise it all the way up (don't have anything hooked up)then by hand you lift up on the lower arms and see how much more travel you get.You want some free play so the hydraulics shut off. I'm thinking 1/2" measured at end of the upper arms will be enough ? Anyhow you can make sure it is getting close to the top.
Ben/Green
03-13-2005 08:22:11
We had to replace the our 3020 cable that went from the lever to the 3-pt. Now it doesn't go up as high as it used to. I don't know what did it. Oh well, still keeps the bales off the ground. have a good day. Ben
thurlow
03-13-2005 11:37:58
 Re: 3pt 4020 in reply to Ben/Green, 03-13-2005 08:22:11
Is the end of the cable not threaded? There are some internal adjustments, also (some can be made from the outside thru the access hole above the serial number plate). You have a manual????? ?????
Toby
03-14-2005 04:32:00
 Manual in reply to thurlow, 03-13-2005 11:37:58
Bought a John Deere Technical manual off ebay but it is for a later serial numbered tractor. I guess I should have know better. My tractor is a 67 and it does not have the same setup. I bought the old tractor at an auction without inspecting and used it yesterday pulling a 8 ton spreader and everything works great. I will have to work on the starting as it does turn slow but it will crank. It has a 12 volt conversion. Strange thing is an old tractor will do the same job as a new one for tens of thousands of dollars less. They sure drive easy.
