Fan Shaft on JD A
GNB
03-12-2005 18:13:45
How much play should there be on the Fan on my 1950 A? Mine has some and was curious. How easy is this to fix for a ameture like me at mechanics on tractors? Thanks
GNB
edchainsaw
03-13-2005 20:01:15
 Re: Fan Shaft on JD A in reply to GNB, 03-12-2005 18:13:45
just want to say.... BEEN THERE DONE THAT MADE THE MESS....
LOL
Mike M
03-13-2005 04:30:53
The only way to set those gears is like FIT says - off the tractor. That way you are setting just the fan gears. You will see extra slop at the fan for various reasons like the play in the cam to crank gear,or cam bearings,or if your fan shaft splines are worn etc. etc. I like to wiggle the fan blades when buying a tractor because if the fan blade has little play and when it runs there are no wierd noises in the gov. or fanshaft you usually have a good one. If you get alot of play add in some noise and you better plan on some governor/fan repairs in your future.
Pat Browning
03-12-2005 21:37:16
You need to be rather cautious here! The fan shaft-governor interface is made up of two beveled gears that have been together a long time. They have wear. The only way you can reduce fan backlash is to remove some of the gasket shims that (by removal) force these two gears together. And one should be careful not to try to remove the backlash at just one side. If you must remove gasket shims, take some from the fan shaft side and some from the governor bearing cover side. It is not a simple task. Screw up here and you will be looking for two rather precious gears! For these old Deeres, a great rule of thumb is to limit fan shaft back lash to one inch at the fan blade tips. Shoot for a range of from 7/8" to 1-1/8" and do not go below 7/8" -- there is no need. (PatB)
Pappy
03-12-2005 19:34:25
According to the scriptures, the fan blade should have about 1/2 to 3/4 inch of free travel.
F-I-T
03-12-2005 18:50:12
GNB:
The spec (which I do not have handy) is to measure the backlash at the intersection of the gear teeth. To do this, you would have to have the fanshaft and governor case dismounted and sitting on your workbench. Not an easy task.
If you knew the diameter of the gear on the fan shaft, and compared that to the diameter of the fan blade, you could say that if the specified fanshaft play was .005" at the gears, and the fanshaft gear was 4" in diameter (2" radius), and the fanblades were 24" in diameter (12" radius), then the .005" play would look like .060" play at the tip of the fanblades. Now I made up those numbers, but that's how you could estimate play with the assembly on the tractor.
If you do choose to remove the fanshaft and governor case to make the adjustment, there are a few things to consider. If you have ever set the heel and lash in a ring and pinion of a differential, then this will be familiar. If you have not, then it can be a bit vexing. You'll need a dial indiactor to do it right.
First you set the heel using the shims on the fanshaft side of the case. Add or subtract shims to get the edges of the gears flush. Then you add/remove shims at the governor shaft (flyhweel side) of the case until you get the correct backlash or free movement using the dial indicator resting on a gear tooth while you rock the opposing gear. After this adjustment, re-check the heel, rinse and repeat.
The I&T manual describes it better than I probably did, but that is the essence.
Now, since many of these gears have been run out of spec for many years, their wear pattern will probably be such that after a correct setting, the gears will whine and howl as they wring in to their correct wear patterns. The problem with this is that as they wear, quite rapidly at first, the heel and lash will be changing. One of the things that I do to alleviate this is to make the adjustment on the bench, and then rig the assembly on my drill press so that I can run it in by driving the fanshaft via the distributor drive lug. This way I can set it, oil it, run it, oil it some more, and when the whining finally begins to subside, I can measure the the heel and lash again, correct if necessary, and run it some more. Once the holwing and whining has decreased substantially, I feel comfortable that it will not howl after installation, and that the gear sets will last for a good long time.
Also, if the gears are very worn, there will usually be a wire-edge burr on the teeth edges. Be sure to stone this off before you begin the setting and running in.
Hope this made sense.
Frank
