1953 John Deere 40S
Terry E.
03-12-2005 16:16:05
My '53 John Deere 40S started fine until today. It has plenty of spark and gas but will not fire. Couldn't start it by pulling it either. I would welcome suggestions.
DMack
03-15-2005 13:43:47
 Re: 1953 John Deere 40S in reply to Terry E., 03-12-2005 16:16:05
Check the points and make sure they are not stuck together. My 55 40T had the same symptoms and the problem was the points. I filed them smooth and reset the gap - fired the first time.
Good Luck,
Dave
buickanddeere
03-13-2005 10:19:37
Gas in the tank or gasoline/vapour mixture in the cylinders? Any water condensed in the bottom of the fuel tank and waterlogged the carb? Any play in that distributer shaft?
Craig Anderson
03-12-2005 21:57:08
Don't know where you live but one molecule of ice in the wrong place will cause that!!! Just had the SAME problem with my 50 which I use at my shop. I put a light bulb on the carb for an hour and that was that.
Hope YOURS is that easy...FRUSTRATING but easy.
Craig
Terry E.
03-12-2005 17:10:46
I forgot to add that the tractor spins over very well . . . it just refuses to fire.
Bus Driver
03-12-2005 16:44:30
If you have a hand crank, turn the engine with it and determine if both cylinders have compression. Sometimes valves stick open for no discernable reason.
Johnbob
03-13-2005 15:03:14
 Re: 1953 John Deere 40S in reply to Bus Driver, 03-12-2005 16:44:30
If it has Champion sparks plugs.See how far you can throw them and buy another brand.
