50 reduction gear oil change
rej
03-12-2005 13:35:49
I took the drain plug out of the reduction gear to change the oil. I know it's suppose to be only 1 quart. But it just keeps on ozing out. Is it possible for the transmission oil to be going into the reduction gear? I checked the transmission oil and it is down a little. If transmission oil is going in there, how much of a problem is it to correct this? thanks, bj
720Deere
03-12-2005 15:37:49
 Re: 50 reduction gear oil change in reply to rej, 03-12-2005 13:35:49
Transmission or first reduction oil? It's all the same. The oil moves from the tranny to the 1st reduction area via the bearings. The 1st reduction plug will continue to drain until the tranny level equalizes at that height. Most people drain both at the same time.
rej
03-12-2005 16:10:16
 Re: 50 reduction gear oil change in reply to 720Deere, 03-12-2005 15:37:49
720DEERE I appreciate that info. Thats what I wanted to hear. This is my first 2 cylinder,even though I have a manual every once and awhile I need information from someone who has hands on experience. bj
rej
03-12-2005 14:06:00
Or does the reduction gear case drain when i drain the transmission oil?
Mike M
03-12-2005 16:00:56
 Re: 50 reduction gear oil change in reply to rej, 03-12-2005 14:06:00
They will flow back and forth,but you should drain them both at the same time and then fill the reduction cover with at least 1 Qt through the top filler plug so it has some for sure. Fill the trans. rear end plug level to the top of filler. Don't forget that if you drain the tranny to also pull out the drain plug under the rear end. You should remove 3 plugs to get it all to drain.
rej
03-12-2005 16:15:06
 Re: 50 reduction gear oil change in reply to Mike M, 03-12-2005 16:00:56
Thanks Mike,next weekend I'll work it out in the field to get that oil good and hot,then pull the plugs,and give it a flush. Y'all have a good weekend. bj
