A Model brakes thrust washer?
Dave in SV
03-11-2005 20:36:54
In rebuilding my brakes, I noticed that there seems to be a part missing on one side. It's item 31 in the parts catalog, page 92, top drawing. It's called a washer, and I think it's intended to be a thrust washer of sorts (?). The stacking order in the parts diagram isn't quite right... it shows the washer between the pinion and the bushing, when actually the washer is supposed to be trapped in the housing under the bushing.
JDParts.com says the part number, 24H77R, is invalid.
ANY SUGGESTIONS?!?!?!?
Mike M
03-12-2005 16:11:21
 Re: A Model brakes thrust washer? in reply to Dave in SV, 03-11-2005 20:36:54
I think you are talking about the shim washers used to take up excessive end play in the brake assemblies. You may or may not need any depending on how much play you have. I think if you have room to place one in without it getting tight that's what the spec. is.
donmyeil
03-12-2005 12:21:02
Just checked Deere parts , drop the R off the end. Part is .036 thick ,outside dia is 2.0, inside dia is 1.625 . Hope this helps. .
Dave in SV
03-12-2005 17:28:28
 Re: A Model brakes thrust washer? in reply to donmyeil, 03-12-2005 12:21:02
Thank you! I measued mine... it's .020 thick, 2.125 OD, and 1.165 ID. If you read Pappy's message, he said that the washer goes as-shown on the exploded parts diagram. That way makes sense... but there's no way the one I have would fit that way... the shaft on the pinion is 2.125.
Again, thanks! I'll check out the part number without the "R".
Pappy
03-11-2005 22:18:31
I rebuilt the brakes on my "A" a few months ago and the washer was exactly as shown in the picture of the parts manual. I can't see how it would fit under (inside) the bushing. The washer is a thrust washer to keep the pinion from wearing the casting.
Dave in SV
03-12-2005 04:06:30
 Re: A Model brakes thrust washer? in reply to Pappy, 03-11-2005 22:18:31
The way you describe it, which is the way it appears in the diagram, seems to make better sense than the way I found mine (on one side of the tractor. The other side didn't have any washer anywhere). In your way, the thrust washer is accessible for R & R without needing to pull the bushing.
Still, JDParts.com says the part number is invalid. Maybe I should take my pinion up to a specialty hardware place and have them match me up with something that will slide over the pinion's collar? My concern is what material and thickness this thrust washer is supposed to be?
Dave in SV
03-12-2005 03:48:00
The washer's inside diameter is smaller than the outside diameter of the pinion. It is positioned such that it provides thrust spacing at the very end of the pinion, not at the shoulder where the pinion's gear is. Does this make sense to you?
Dave Brennan
03-12-2005 05:05:23
 Re: A Model brakes thrust washer? in reply to Dave in SV, 03-12-2005 03:48:00
When a part comes up as invalid, it means it is no longer avalible though Deere. Not that it is not used. Search some tractor parts salvage yards for the right washers or put an add in the classified section of this web sight.
