How to Break an Old Weld
JKC
03-11-2005 19:45:17
I have discovered that many years ago, someone welded one of the cultivator brackets onto one of my old tractors to give the cultivator "extra support", I guess. The question is: This bracket was welded directly to the cast on the tractors front end. What is the best way to break this weld and remove this bracket? ANY suggestions would be very much appreciated.
MB in NE
03-11-2005 20:10:11
 Re: How to Break an Old Weld in reply to JKC, 03-11-2005 19:45:17
JKC, the best way I know of instead of breaking the weld, witch could break other things in the process, is to try and get in there with a grinder. Preferably with a cut off wheel on it. If it is in a tight spot, us a die grinder. Hope this helps.
Dave Brennan
03-12-2005 05:14:34
 Re: How to Break an Old Weld in reply to MB in NE, 03-11-2005 20:10:11
Yeah, I agee with JKC. The best way is to grind the weld as much as possible. I've also used a tourch to burn the old weld and part away taking care not to cut into the part you are trying to save and then grind the surface afterward. Happy Trails and Good Luck! Dave!
Tye
03-12-2005 14:42:03
 Re: How to Break an Old Weld in reply to Dave Brennan, 03-12-2005 05:14:34
In addition, if you do cut into the tractor, don't sweat it- weld up the cut then grind it down to match. Good luck! -Tye
Ken in Mich
03-12-2005 17:54:53
 Re: How to Break an Old Weld in reply to Tye, 03-12-2005 14:42:03
Lots of ways to do it, depends on what tools you have to work with. First, would be an arc-gouge. (air carbon arc)
Second, grinder with cut off wheel
Third, torch using a oxidizing flame (heat until the metal starts to melt, then turning up the oxygen to wash the weld away)..or using a cutting torch head.
Fourth, sawzall
