2010 highlift Review!!
StephenMO
03-11-2005 18:18:52
This is a review of what I did today on the 2010 highlift that is near the bottom of this forum. I fiquered out one major detail that had me wasting my time for about 3 months. Turns out that the rotor turns in a counter-clockwise motion. I had set up the plug wires to go in a clockwise motion. That was one major discovery today. I found out that the fireing order is 1-3-4-2 and I used my finger to feel the preasure building up in the #1 cylinder to find out what order to put them in in the distributer cap. I tested the coil both with the original wire from the swithch and from a hotwire straight from the battery. Both times i had a strong blue spark jump from the end of the coil wire. The problem is in my cap. right?. I had bought a brand new rotor from the John deere dealer that is just down the road. I tested to see if there was any spark coming out of the plug wire. I could not get it to spark. I even put a piece of electric fence wire and substituted it for the plug wire and I couldn't get that to spark. Somebody told me that the reason that i'm getting so much spark when I spread the points is because either my conderser is bad( witch I did replace but you never know, it could be bad) or I have my coil wires mixed up. I will look in to that tomarrow. In the mean time I need some help trying to get spark to the plugs. Is there any tests that I can do to rule out any other parts that might be bad or mixed up. Will a 4-cylinder cap from a Farmall M work on this Crawler? It should because there both delco-remy. I think there might be problem with the plastic piece that goes on before you install the rotor. The one on it doesn't fit right. Could that be a problem? I also gathered some information so you guys know what I'm dealing with. My dad said it's a 1965 model(withch is really cool because they only made 6 gas models that year). Serial # 3984 I haven't checked to really make sure it was a 65 model. Thats what my grandpa always told my dad. It ran good until one day they stopped using it because it was getting dark and when they whent back to start it, it wouldn't start so they parked where it sits today. I'm really getting close to getting it started and my exitement is really building. I would like to thank everyone who has given me feed back and I will continue to tell you whats going on. Thanks to everyone!
Stephen
jdemaris
03-11-2005 20:26:16
 Re: 2010 highlift Review!! in reply to StephenMO, 03-11-2005 18:18:52
2010s used four different distributors. Make sure you don't have parts mixed up. Delco distributor cap and rotor (bolt-on cap) is R11257 & R11260R; Delco distributor cap (clip-on) and rotor is 811735 & 820445 Wico cap and rotor is AT14190T & AR12001R, and Prestolite cap and rotor is AT 14692T & AT14680T. If you're sure spark is coming out of the coil, and you're sure the distributor shaft is turning (where the rotor goes on to it), then the problem must be in the cap and rotor - unless you've got some incredibly bad plug wires which is unlikely unless someone replaced them with some old carbon automotive wires. Take the cap off, lay it upside down, lay the rotor in it and eyeball it. Either it looks right, or it does not. If the center conductor is intact (metal on the rotor, and carbon on the cap, and the end of the rotor comes fairly close to the poles in the cap for each cylinder - then it ought to work. If you've got enough spark to jump a 1/4" gap elsewhere, it will also do it through the cap - and if it doesn't - seems you've got an awful big gap somewhere. Only spot you can't actually see is the coil center-conductor where is goes through the cap into the carbon pole. If sure about it, test it with an ohmmeter.
StephenMO
03-12-2005 09:02:21
 Re: 2010 highlift Review!! in reply to jdemaris, 03-11-2005 20:26:16
Thanks. I will not use the cap from the farmall. I will replace it with one from the dealer. It has Plug wires that don't have wire in them, it has some with a black flimsy type material. Could they be the automotive wires you were talking about. Remember that it used to have spark but not all the time and it varied it strenth. The old plug wires are laying around somewere. I will clean them up and try them. Thanks jdemaris you've been a big help. Keep looking for other post about the 2010. I can't waight to hear that motor run. It so close. Thanks Again!!
jdemaris
03-12-2005 09:32:13
 Re: 2010 highlift Review!! in reply to StephenMO, 03-12-2005 09:02:21
If the plug wires don't have wire in them, they are not original and I wouldn't use them. They are probably old carbon resistor automotive wires. When in excellent shape they can take very high voltage to work, and when in bad shape, their resistance will often exceed what a tractor's ignition systems is capapble of using. You can put a ohmmeter on them if you want to check - but do yourself a favor and buy some copper-conductor plug wire - like Packard 440 or an equivalent.
StephenMO
03-12-2005 09:44:47
 Re: 2010 highlift Review!! in reply to jdemaris, 03-12-2005 09:32:13
Thanks. I will have to do that. They look to be really new. Oh well, I'll just get new ones. Thanks again
jdemaris
03-12-2005 10:23:44
 Re: 2010 highlift Review!! in reply to StephenMO, 03-12-2005 09:44:47
I don't want to mislead you. If they are new resistor wires, they may be fine. You'd have to check with an ohmmeter to be sure. Modern resistor wires, for the most part, are much better quality than they were 20-30 years ago.
Gerald J.
03-11-2005 19:52:52
If you get a good spark off the coil but not from the distributor you have problems in the distributor.
It could be that the thin plastic cover is keeping the points from closing.
It could be that lack of lubrication on the points pivot keeps the points from closing rapidly. This happened to my gas 4020 a couple years ago out in the field.
It could be that the electrodes on the inside of the distributor cap are eroded from sparking and from sitting nearly in the weather to make a gap the spark can't jump.
It could be that the centrifugal advance has moved the cam so that the rotor doesn't point to a cap stud when the points open, or that the point gap is too far off from the right setting for that alignment to happen. Though usually the rotor and cam are locked together so they advance together.
It could be that the rotor you have is the wrong one and it doesn't get within a quarter inch of the studs inside the cap.
It could be that the rotor isn't on the shaft in the right position.
It could be that the cap is porous and with liquid on it from dew it shorts out the ignition. I had a Ford truck that would do that every 30,000 miles or so. Or is so dirty inside that its shorting out the spark.
It could be that the distributor shaft is broken or the gear stripped or the gear or coupling pin sheared so the distributor runs slower than it should.
Gerald
KEH
03-12-2005 10:35:52
 Re: 2010 highlift Review!! in reply to Gerald J., 03-11-2005 19:52:52
I had a 2010 JD gas tractor which gave trouble starting, ran bad, burned out points often. Turned out the trouble was a bad ignition switch. You might want to check that out.
KEH
StephenMO
03-12-2005 15:22:14
 Re: 2010 highlift Review!! in reply to KEH, 03-12-2005 10:35:52
Yeah the points are burned and my dad said it always had a hard time starting. I think i will go get a new switch. Right know it has a switch from a battery powered lawn mower. Thank You.
StephenMo
03-11-2005 20:01:59
Thanks. Those are all really great tips. Can't waight to try them out.
msb
03-11-2005 19:00:21
First of all, your condenser is not bad or you would not get that blue spark.The primary winding of a coil is loaded once it receives power( when you turn the key on).When the points close,the primary windings load the condenser.Then when the points open, the condenser unloads its current into the secondary windings of the coil and a spark occurs when the secondary windings go to ground.A coil will only generate enought voltage so the current can go to ground.The wider the gap, the more current it takes to go to ground.So, it can produce 5,000 volts or maybe up to 24,000 volts.
No, the Farmall M distributor cap might not fit.I wouldn't even try it.The wire from the coil to the distributor should be the same as the gound,so if it has a positive ground on the battery then the wire to the distributor should attach to the positive terminal on the coil.I would replace the distributor cap although your spark plug wires could still be a part of your problem,so I would also replace them.Since they are that old the terminal ends are probably ready to be replaced anyway.
The dust cover inside the distributor needs to be turned a certain way before it will fit.Turn it until it snaps into place.There should be some notches that need lining up.Sounds like you are about to hear it run once again.Grandpa would be very proud of you.
StephenMO
03-11-2005 19:08:21
 Re: 2010 highlift Review!! in reply to msb, 03-11-2005 19:00:21
The dust cover is a really thin plastic not like a one on a farmall. It doesen't even have notches to let me know where it is suppossed to go. Thats why I think its not the right one. I can't wait till she fires up, it is such an incredible feeling of acomplishment. I worked on our JD 60 after not running for about 3 years. That was undiscribabile to hear them two cylinders fireing. It's like it came back from the dead. Completely awsome.
