730 powertrol lever won't return to center
ol'George
03-11-2005 15:44:13
Hello, Maybe someone can help ????? ???
A few years back I installed a complete DUAL outlet powertrol control valve assembly on my 730 Diesel,in place of the single outlet control valve assembly. The single control assembly always returned to netural, as it should, when the Hyd. cylinder fully extended or retracted.
The dual control assembly will not "kick off"(return to center) when the cylinder(s) fully extend or retract. The lever(s) stay in the detent position(will not return to netural) and the relief valve squeals. Both cylinders(valve/circuits)
malfunction exactly the same. everything works properly,other than this problem.
I use the tractor to plant with my JD 7000 planter.
The dual outlets are more desirable, for the marker cylinder(single acting),and lift cyl (double acting) I have dissambled the unit as per service manual but cannot find anything wrong. I have checked pressures, check valves,crossed passages ect. The book says that they should return to center. It will function as it is, but I have to remember to return the levers back to center as it is a strain on the system when I forget. Any sugestions?
thanks in advance,
ol'George
