Carb Problem, Maybe
Green '52'
03-11-2005 14:47:45
I have a dltx 67 carburetor. The throttle shaft has axial movement, I think it is axial. Anyway up and down with the carb on the tractor. I have about 1/4" movement, will this affect the idle adjustment? Also, in the throat by the throttle plate I have very rough metal about 10 to 15 thousand grooves. It is on a '52' B.
Do I need rebuilt carb here.
Thanks for your input
Duane Larson
03-11-2005 20:38:30
 Re: Carb Problem, Maybe in reply to Green '52', 03-11-2005 14:47:45
Green '52',
Sounds like you have a worn throttle plate. They should be perfectly round - your's is worn at the bottom end and has worn grooves in the body casting. The easy solution is to get a new throttle plate, throttle shaft, and shaft bushings (turn your own plate, or contact www.robertscarbrepair.com for parts) - plate dia is 1 3/8". Clean the worn grooves (preferably by beadblasting), fill them to the proper level with JBWeld, and file to the contour of the throat after it dries. This normally solves the problem. If the grooves are particularly bad, the best solution is brazing and grinding to fit.
