2 cylinder Tachometers
Foggymoon
03-11-2005 13:57:30
Does anyone have any info on somebody or business that sells reproduction tachs or will repair original tachs. Thanks Keith
TIMAR
03-12-2005 10:51:20
 Re: 2 cylinder Tachometers in reply to Foggymoon, 03-11-2005 13:57:30
If your old tach has a good face I can repair it. Usually runs $125-$150 depending on the parts needed
Jim Dunn
03-12-2005 03:16:50
Is your tach in such bad shape that you wouldn't want to use it again? I had one on a 520 that hadn't worked for a number of years due to worn gears inside the governor housing. Since the tach hadn't worked for so long, it just seemed to stick in that position. I soaked the drive section of the tach with penetrating oil for a couple of days and was able to free it up with a pair of pliers rotating the drive. Once I got that freed up, I made a pin to drive it and chucked it up in the lathe and just let it sit there and rotate for a couple of hours, changing the rotating speed a couple of times. It is working fine so far. Might be worth a try.
JDVan
03-11-2005 15:59:14
JD sells substitute generic (Universal) Tachometers for the two cylinder tractors. In many cases they do not read totally accurately for a specific model relative to RPM, Ground Speed, PTO RPM's and possibly Hours because they are kind of a "Universal model"
Nick Barbieri sells "New" Borg Warner Tachometers which he modifies by opening the case and changing the face of the BW Tachometer so that it reads correctly for a given specific model of tractor. In some cases I beleive he also changes the gearing, if required, to make sure the "hours" are also correct but not usually required on 1:1 standard tachs. The modifications Nick makes adds about $100 or slightly more to the cost over JD's Universal Tachometer. I think he also does Tachometer repairs.
JDVan
03-13-2005 16:24:20
 Re: 2 cylinder Tachometers in reply to JDVan, 03-11-2005 15:59:14
I have a typo in this message. I intended "Stewart Warner" not "Borg Warner" Sorry for the oversight.
JDVan
03-13-2005 16:24:38
F-I-T
03-11-2005 14:13:26
Some of the tachs are still available through the dealer.
What model are you interested in? I might be able to look it up on JDParts.com
Frank
foggymoon
03-11-2005 20:31:26
 Re: 2 cylinder Tachometers in reply to F-I-T, 03-11-2005 14:13:26
Thanks for the info. I did check with the dealer. They are no longer available for the 60
CLW
03-11-2005 20:41:36
 Re: 2 cylinder Tachometers in reply to foggymoon, 03-11-2005 20:31:26
Like JDVan said, Nick Barbieri (516-221-4116) has them.
CLW
