4020 charge/light
James L
03-11-2005 05:56:33
I installed a 12-volt conversion kit on my 65 4020,I started it up it would not charge, the light stayed on. So when I checked there was power going to the light but no power coming from the light to the alternator. I have the red wire from the Ign. switch termial LTB to the GND. on the indicator light, from the bulb the BK. wire goes to the ALT.#1 Ign switch terminal. When I bypass the indicator light it charges good when I check with a multimeter. Can anyone help? Thanks.
Dave Brennan
03-11-2005 06:19:56
 Re: 4020 charge/light in reply to James L, 03-11-2005 05:56:33
I had a similer problem with a 3020 not long ago. I ended up changing the wires and the indicator light and then It would charge. The old light would stay lit all the time, I assume it did not provide enough backfeed to excite the alt, although it seemed ok when i checked it with a mulimeter. Drove me Nuts!!! Good Luck and Happy Trails, Dave!
James L
03-11-2005 22:01:42
 Re: 4020 charge/light in reply to Dave Brennan, 03-11-2005 06:19:56
Thanks Dave, You were right i cleaned it up put a new bulb in works perfect. Thanks again.
James.
Dave Brennan
03-12-2005 15:45:23
 Re: 4020 charge/light in reply to James L, 03-11-2005 22:01:42
Glad I could Help! Happy Trails, Dave!
