1939 John Deere L Seal Removal
Larry Kastens
02-18-2004 15:53:43
What is the procedure to get at the rear axle seal? I have removed the plate under the differential and the stud holding the axle. Would the next procedure be to remove the three studs that hold the retainer plate (there isn't much room between the studs and the axle flange)? I loosened the studs and tried using a slide hammer on the wheel studs but I don't want to break anything. Thanks for any help you can give me.
Dwqayne
02-18-2004 19:43:54
 Re: 1939 John Deere L Seal Removal in reply to Larry Kastens, 02-18-2004 15:53:43
use those three bolts behind the rear axle as your press, loosen each of them aginst the axle 1/4 turn untill they are all the way out, that will get your axle started moving. once you doo that, you can use a hammer with a bronze punch to drive the axle the rest of the way out.
