4320 vs. 4020
PJBRown
03-11-2005 05:06:47
I have found a 4320 that's in great shape for $11,000. The 2 questions I have are how do they compare to the 4020 work wise..... and how do they compared value wise..... is there a demand for them like the 4020?.
JDBert
03-11-2005 06:21:14
 Re: 4320 vs. 4020 in reply to PJBRown, 03-11-2005 05:06:47
720Deere pretty much covered it all. Except the engine is a little more then just a turboed 4020 motor. They are built a little heavyier with higher capacities for oil delivery and cooling. The rearends are also built heavier then a 4020. The 4320 was kinda a "high bred" between the 4320 and the 4620.
720Deere
03-11-2005 05:25:03
The 4320 was only built for 2 years. I don't know the exact numbers, but I think something less than 15,000. They usually bring $2000 to $3000 more than a 4020 in the same condition. the 4320 was only available in synchro-range transmission. Same basic motor as the 4020 but turbocharged. Most 4320s dyno 120 to 130 hp right out of the box even though they were only rated 116 hp. My unlce has both a powershift 4020 and a 4320, so I have experienced both first hand.
The 4320 will easily pull one more plow bottom than the 4020 as the hp difference is tremendous. They both handle about the same, very nimble for tractors their size. We used to pull a 2 row chopper with the 4320 in 3rd gear most times where a 4020 would usually be low to 2nd gear in the same conditions. For most work the 4320 is more fuel efficient than the 4020. It's not a huge difference, but it was documented in the Nebraska tests and has also been my experience with the two.
The demand seems to be growing for the 4320 as in it's category, it is cheap hp. Compared to the long revered 4440 in price, it is a huge bargain. Even against a 4430, it's still cheap and I'm not sure I would put a 4430 against a 4320 in the field. I think the demand for these tractors will continue to grow as a new replacement for the same hp is nearing the $100,000 mark. Overall the 4320 is good investment and a great tractor.
Mike M
03-11-2005 05:23:57
I kinda thought they were in more demand.
856puller
03-11-2005 15:32:22
 Re: 4320 vs. 4020 in reply to Mike M, 03-11-2005 05:23:57
when i worked at a jd dealership 5 years ago the head tech, who had been there forever, said the 4320 was the best tractor deere ever built
