mag timing JD R
bassndeere
03-10-2005 17:45:46
Hello,
Any secrects to timing the magneto on the pony motor of a JD R? Got spark, gas and compression, still won"t start, WHY ?
Thanks,
Don
Tony W
03-13-2005 02:32:27
 Re: mag timing JD R in reply to bassndeere, 03-10-2005 17:45:46
I had the same thing on my 50, if you are getting spark timing may be ok. On the little fuel pick up tube there is a same check valve that does stick if the fuel is bad. Just spray some carb cleaner and make sure that is free and then try. Timing marks are on the flywheel inside the clutch cover with access on the right hand side over the main clutch. It is a pipe plug, remove it and rotate the engine with a long screw driver and listen to the click on the mag with the line on the clutch. Best of luck. How about a few pictures
bassndeere
03-15-2005 18:54:51
 Re: mag timing JD R in reply to Tony W, 03-13-2005 02:32:27
Hey Tony W., Please send me your e-mail address so that we can talk JD's. Thanks for the advice on the check valve. My JD R is a 1949. Thanks again,
Don
Dave Brennan
03-11-2005 06:01:46
Just a thought, I had a problem starting a pony on my dads 830 diesel awhile back. The tractor sits for a long time and I found the gas goes bad. I changed the gas and then it ran. I never worked on an R so I can't help you much there. Happy Trails, Dave!
