lift problem on a 2030
jim u
03-10-2005 13:49:02
I have a 2030 with a front loader, My 3 point wil not lift from the draft control lever but, when I curl the bucket the lift arms work great.What could be the problem?
cannonball
03-11-2005 04:47:23
 Re: lift problem on a 2030 in reply to jim u, 03-10-2005 13:49:02
stroke control valve on front pump..... have nice day may god bless
ky parts
03-11-2005 05:44:06
 Re: lift problem on a 2030 in reply to cannonball, 03-11-2005 04:47:23
If your loader and steering is working ok I would bet its not the stroke control valve!
TimberOak
03-10-2005 18:47:54
Sounds like you might have an open center valve on the loader rather than a closed center valve.
Has this loader been on this tractor and worked normally before or have you installed a new loader valve
Are you operating the loader with a seperate loader valve or with the tractor selective control valves?
