620 Running On One Cylinder
Salty
03-10-2005 07:12:35
I have been restoring a 620 and have it running only on #2 cylinder unless I choke it and then it also runs on #1 until #2 floods out. I had the carb professionally rebuilt plus I have been through it twice by blowing out all orifices. It has all new wiring and a new ignition system. The coil chrcks out at 1.6 ohms across the two small terminals and the inline ballast resistor records 2.2 ohms. #2 cylinder has 122# compression and #1 has 112#. I have removed the manifolds and made sure nothing is restricting and installed new gaskets. My gut tells me there is still something wrong in the carb but what do you guys think?
Dennis
JDVan
03-10-2005 13:01:45
 Re: 620 Running On One Cylinder in reply to Salty, 03-10-2005 07:12:35
I had an identical problem on my 1958 JD 620. I needed to have the carburetor professionally redone which requires removing the swaged in steel balls to get to all the passages and to do the job right.
Many so called professional rebuilders don't do that, just soak it and clean the passages they can get to w/o removing the steel balls.
I would highly recommend Roberts Carburetor Repair in Spencer, IA, who does remove the balls to clean ALL passages and also tests the carburetor on a running two cylinder engine to make sure the carburetor has been truly repaired.
Unfortunately you may have a several week wait as their backlog is extensive but it is worth the wait.
Carl NY
03-10-2005 07:32:15
Salty. Check to see if you have sufficient supply of gas to the carb. The oil pressure gas shutoff/ sediment bowel unit could be a culprit. I have had to replace many rubber diaphrams on these units lately. If you have a good fuel supply, you then have blockage in the carb.
Arthur Driesse
03-10-2005 07:21:51
Just finished cleaning out the carb on my 60, I had the same problem. I blew it all out an poked a wire through any holes or orfices I could find. Doesn't take much to plug it, even a speck of dirt when reassembling it, I did mine twice over. Good luck Arthur
