Another 2950 hyd question.
53/60jd
03-09-2005 19:28:27
where is the hyd pressure adjustment for a 2950 tractor thanks
Gord
03-09-2005 23:03:43
 Re: Another 2950 hyd question. in reply to 53/60jd, 03-09-2005 19:28:27
The main hydraulic pump pressure is set by adjusting the stroke control valve screw. The screw is an allen head screw with a lock nut on it under the main hydraulic pump. Loosen the lock nut(3/4" wrench). Turn the screw in until you get 2350 psi at the rear couplers then tighten the lock nut.
