2950 front hyd pump question
53/60jd
03-09-2005 17:30:06
My father in law has a 2950 with the front pump. He said the hyd were suppose to have about 2000psi and he is only getting 1800. there is a screw adjustment there and the question is does turning it in or out raise the pressure. thanks Chris
Walter Squires
03-10-2005 07:33:04
 Re: 2950 front hyd pump question in reply to 53/60jd, 03-09-2005 17:30:06
A 2950 should be at 2250 (+ - 50) PSI, The screw with a jam nut on the pump is the stroke control valve, put a pressure gauge in the selective control valve on the rear of the tractor, activate the valve, see what the pressure reading is, turn the screw in for more pressure, out for less.
Good luck, Walter
Dieselrider
03-09-2005 19:19:07
I think that screw is just for eliminating the pressure to make the tractor easier to start if the battery is low or the weather is real cold.
