59 JD 730 Diesel
Mike in Kentuck
03-09-2005 13:50:36
I recently aquired my 730D. the tractor is original. I was wondering if the RPM's could be turned up or the fuel to get a little more out of it in it's stock form and if so how would I go about doing it. this is the 1st Diesel 2 cyl. I've ever been around and I'm not to well educated on them.
buickanddeere
03-10-2005 09:06:48
 Re: 59 JD 730 Diesel in reply to Mike in Kentucky, 03-09-2005 13:50:36
Put her on a dyno first and see if she will make stock HP. Odds are you will be happy once she's repaired and making factory rated power.
That 730 and most other two cylinders are rapidly loosing volumetric efficiency after max rated HP and rpms. Turning them faster just draws less air or air/fuel mixture into the cylinders on the intake stroke.
msb
03-09-2005 19:38:03
Mike,there is a good chance you will throw chunks of the weights off the govenor if you increase the RPMs by 200.Been there ,done that many moons ago.Should your govenor action seem a little odd then suspect it has happened.
JLG
03-09-2005 14:41:13
Look at the linkage from the throttle lever into the govenor. There"s an adjustment behind the dash that will let you raise the RPM"s. Just go a little at a time, and if you go too far you"ll have to shut it down with the decompression lever. And also remember that it"s a 45 year old tractor, so dont go too nuts. Making sure the pumps and injectors are up to snuff is also worth the time and effort. Really made mine come alive.
Mike in Kentucky
03-09-2005 15:21:16
 Re: 59 JD 730 Diesel in reply to JLG, 03-09-2005 14:41:13
thanks I'll try that.I'm having the tach. replace so i wont bump it more than 200 rpm
mike brown
03-09-2005 15:43:00
 Re: 59 JD 730 Diesel in reply to Mike in Kentucky, 03-09-2005 15:21:16
On the left side of the engine block up above the cylinders (Rounded Part) you will see where the arm from the governor comes down to the end of the fuel injector rack. There is a convex plug that hides the adjuster for rack travel. It looks like a set screw with a lock nut. If it is backed out the rack can move farther giving more injection quantity when the governor senses a load is pulling down the rpms. There is also a spring adjustment on the front side of the governor (under a cylindrical cover)that when backed out allows the governor to respond to load more quickly.
Mike in Kentucky
03-09-2005 17:08:37
 Re: 59 JD 730 Diesel in reply to mike brown, 03-09-2005 15:43:00
thanks guys for the info I have uncovered my email.I would enjoy it if yall would email your phone #'s to my address or your emails I have several questions and dont have the tractor readily available since I'm working in Iraq.
Metal Master
03-09-2005 17:43:41
 Re: 59 JD 730 Diesel in reply to Mike in Kentucky, 03-09-2005 17:08:37
Uh ... Oh ... you are getting bit by the John Deere Bug ... it gets worse, not better.
I just bought a Johnnie just like yours, same year, etc. ... just for a working tractor. I have been advised to keep it as stock as possible while I am making repairs/upgrades. I was lucky to get the owner's manual with it, which is very complete ... then invested in sending for a shop manual off this site. It came quickly ... a nice, shiny new one. THAT SHOP MANUAL IS SUPER COMPLETE with the wiring diagram ... the 24 volt system is quite complicated. A lot of the parts on the tractor have an exploded view. This will give you something to do to unwind when you get back home ... good luck! The link below is to my AOL journal ... just, mostly for my own kicks ... I'm putting John Deere links on it until I get around to doing a web page for my website.
Mike in Kentucky
03-09-2005 17:59:14
 Re: 59 JD 730 Diesel in reply to Metal Master, 03-09-2005 17:43:41
I'll be back in Ky at the end of May for R&R. I also have a Modle A. I've got a JD machanic workin on them in his spairtime.The 730 I drug up off a montain side out of the woods were it had rested for 5yrs to my amasement it started &run but needs a lot of TLC.The A has been in & out of the family since I was 4. It is part of my earliest memories.needless to say it's got a home now as long as I'm alive anyway.and good luck with yours.
