4020 moldboard plow
gwece
03-09-2005 06:31:42
I have a moldboard plow question. I would like to pick up one to plow some of my pasture ground here in southern Illinois that hasn't been broken up in 25 years so I can level it a bit better and then reseed. I recall back in the 70's using my uncles' 4020 and a JD 5 bottom semi-mount plow that he called a "trash plow". That rig was a plowing duo! The plow was high clearance and would turn about anything under and never seemed to "ball up" with trash. Does anyone have any idea what model of plow that could have been and/or where I might locate one? Thanks
JDBert
03-10-2005 06:45:15
 Re: 4020 moldboard plow in reply to gwece, 03-09-2005 06:31:42
I would shy away from the 1350-1450 plows, they have a turn buckle in the front and are hard to keep adjusted and plowing good, F145's are getting hard to come by, I see some 1350-1450's on lots here in MN and then I think the next step newer is the 2500 series plows.
Farmer Jack
03-09-2005 09:31:28
Might be a 5-14 or 5-16 F145 or F1450. Your uncle probably had trash boards mount to the shank which holds your frog (plow bottom). these will turn the trash into the furrow before the soil closes the furrow (thus burying it).
