4230 remote connectors
txblu
03-09-2005 06:22:50
This new whangled dangled thang of mine has some fancy caps to keep the dust out of your remote connections. They are thin and pliable and you just push them into the sockets (Old Deere Style).
I only hooked remotes up to this tractor once but that was before I discovered the "float" position on the hyd control lever.
In hooking up that time, I removed the rubber covers and had to pull the rings out (with the balls in them) to get it to accept the hose whereupon I damaged the gaskets and had to put new ones in before I could use it.
Well I put the covers back on yesterday and in doing so the rings pushed in again.
Question if you please: With the control in the "float" position and the rings pushed in, will it accept the hose fitting, or will I have to pull the rings out again which means every time I disconnect the implement and want to keep the dust out I have to go thru this rig-a-maro. Hopefully not.
Thanks,
Mark
txblu
03-09-2005 08:43:51
 rapture in reply to txblu, 03-09-2005 06:22:50
You guys are it. Did it again.
Got dressed and went to the shop and checked the 4230 and sure nuf. Little pressure on the back (which I had thought was inaccessible) and she popped right out. Hmmmmm m OK! So I went to the 4010 and sure nuf. Same thing. Geezzzzz z. Whatta day.
Can't believe it. Had these vintage size/type Deeres for over 5 years now and didn't realize the lock was accessible from the back.
Thought I was naturally inquisitive and possessed some common sense..... .Oh well.
So I came back in and cranked the ole computer back up and am sending out my thanks for a job well done. You really made my day as I hated to connected an implement cause it was so much trouble.
Thanks again.
Mark
thurlow
03-09-2005 08:12:52
 Re: 4230 remote connectors in reply to txblu, 03-09-2005 06:22:50
HTR and msb are of course both right; the barrels/connectors shouldn't be that stiff; are they rusty or has it been sitting in the weather for some time? If you continue to have trouble, Deere makes a little kit, consisting of a lever which mounts on each connector and easily moves the barrel back and forth. Much easier to make connections with no oil pressure; shut tractor off and move control lever back and forth a time or two to relieve oil pressure.....
HTR
03-09-2005 07:20:54
Reach around back of the coupler, and pop the the barrel back out. The coupler barrel extends through the housing. Doing it this way will pretty much pop the dust plug out.
txblu
03-09-2005 07:36:34
 Re: 4230 remote connectors in reply to HTR, 03-09-2005 07:20:54
Well I'll certainly check that out. You may have made my day..... didn't think you could access the rear of the coupling unit from the back like on the new Pioneer couplers.
Thanks much in advance.
Mark
msb
03-09-2005 06:55:30
You do have to.
txblu
03-09-2005 07:34:26
 Re: 4230 remote connectors in reply to msb, 03-09-2005 06:55:30
Yuck!
Thanks, but no thanks if you know what I mean. You'd think mother Deere was smarter than that.
Mark
