466 in 4020
Jd 4020 3020
03-09-2005 05:26:49
A neighbor of mine asked me to post this to ask for info. on putting a 466 natural motor out of a 7720 combine into a 4020. He is looking for some advice from someone who has done this or seen it done before. The main problem he is running into is fitting the water pump, and fan between the motor and radiator. He is wondering if there is a different fan or water pump that he needs to use to do this. Another limiting problem here is the tin cover over the front of the motor with the oil fill plug. Does this need to be changed, or will there be enough room to keep it without the fan belt rubbing. Also does he have to move the radiator ahead, or will everything work where it currently is. It can be moved an inch or so, but would requir some work to do. He has had the front pulley machined down to fit the hydraulic coupler in, so that is one less problem to deal with. Sorry about the long post, but hopefully someone will be able to decipher this and lend some advice.
tad ingram
03-09-2005 16:45:45
 Re: 466 in 4020 in reply to Jd 4020 3020, 03-09-2005 05:26:49
i have done a 404t myself it isnt alot of trouble and you dont need to lengthen the hood or change the frame rails. you have to use the 4020 fan but you have to have a spacer made to put behind it, you will also need to cut out the cross piece in the bracket that holds the hydraulic pump on. the fan shroud can be cut so that you dont have to move the radiator if you take your time it can be done verry nice if i can find some pictures of my old one i could email them to you. it seems like the radiator hose on the bottom had to be changed also. with a naturally asperated motor you should have no problems with the tin. you also have to make your throttle linkage as well.
JD 4020 3020
03-09-2005 17:58:21
 Re: 466 in 4020 in reply to tad ingram, 03-09-2005 16:45:45
My Email address is [email protected] If you find those pictures we would greatly appreciate it! Also could you drop me an e mail, as I can tell you what point the project is at and I have a couple specific questions that you might be able to easily answer. Thanks for your help!
Jim J
03-09-2005 16:36:45
The biggest secret is a set of 4320 side frames. You will also need to lengthen the hood.
JD Jack
03-09-2005 19:20:18
 Re: 466 in 4020 in reply to Jim J, 03-09-2005 16:36:45
Aren't the 4020 and 4320 frame rails the same size?
Nathan (SD)
03-09-2005 07:55:40
 Re: Ahrendt Clark in reply to Jd 4020 3020, 03-09-2005 05:26:49
A dealer in Iowa does these conversions on a regular basis. I think they are in NW Iowa.
JD 4020 3020
03-09-2005 09:29:59
 Re: Ahrendt Clark in reply to Nathan (SD), 03-09-2005 07:55:40
Would anyone know a possible phone number or e mail to contact them at?
Jeff Jacobsma
03-09-2005 10:08:24
 Re: Ahrendt Clark in reply to JD 4020 3020, 03-09-2005 09:29:59
Sibley, Ia 712-754-3742
speak to Ivan
JD 4020 3020
03-09-2005 18:00:31
 Re: Ahrendt Clark in reply to Jeff Jacobsma, 03-09-2005 10:08:24
Thanks! I'll have my neighbor give them a call.
