'49 A Crankcase breather tube?
Dave in SV
03-08-2005 14:20:55
My '49 A has a metal tube running from the top of the rocker cover to just upstream of the carburetor. I'm guessing it's for some sort of crankcase venting...? The tube is twisted at the "carb" end, so much so that I doubt it passes anything. I cannot find anything about this tube in the I&T JD-4 or the JD Parts Catalog. It's easy enough to make a new one with tubing and a flaring tool, but I'm curious what it's for and why it's not in the catalog.
HELP?!?!?!?
Mike M
03-09-2005 05:33:37
 Re: '49 A Crankcase breather tube? in reply to Dave in SV, 03-08-2005 14:20:55
On a more modern automobile this would be like the PCV system they use.
F-I-T
03-08-2005 17:00:19
Dave:
If it"s like our "48 "A" (and I believe it is...) you want P/N AA 4033 R, item #16 on page 75 of the parts book. It"s a lazy 90* turn from the top of the valve cover to the threads on the carburetor inlet pipe. That directed the fumes collected from the valve cover and pushed there fby the fanshaft ventilator pump to the carb inlet for reburning.
Frank
Dave in SV
03-08-2005 18:26:49
 Re: '49 A Crankcase breather tube? in reply to F-I-T, 03-08-2005 17:00:19
Sounds exactly like what I have! I'll check my parts catalog, per your info...
Ventilator pump? What's that? (yeah, I know... I sound like a real rookie!)
Dave Brennan
03-09-2005 04:03:15
 Re: '49 A Crankcase breather tube? in reply to Dave in SV, 03-08-2005 18:26:49
The ventilator pump is just behind the fan on the fan shaft and is used on late production tractors. Yours should be with in that range.
Dave Brennan
03-08-2005 14:54:28
You may have an older style rocker arm cover on this tractor. The early "A"'s through 39 had a pipe that ran from the governor housing to the top of the valve cover that provided oil to the rockers. Starting with serial number 488000 the rockes were oiled internally.
Dave in SV
03-09-2005 03:31:04
 Re: '49 A Crankcase breather tube? in reply to Dave Brennan, 03-08-2005 14:54:28
The tube I am talking about goes to the air inlet pipe just "upstream" of the carburetor, not to the governor. But thanks for the info.
