720 gas lower coolant pipe
Chaterman
03-08-2005 14:12:21
I fixed a water pump on a 720 standard gas tractor for a neighbour. I installed the pump, put a new o-ring in, pushed the coolant pipe into the pump, and then tried to install the cast fitting that goes on the end of the pipe and bolts on to the underside of the cylinder head. This fitting also got a new o-ring. However once you get this fitting pushed on the pipe, it is too long to slide up into place and catchs on the frame of the tractor. I can not seem to push the pieces any closer togeather. Is there any particular order these pieces go togeather or is there something I am missing? My usual source for JD advise passed away this winter so any advise would be appreciated.
F-I-T
03-09-2005 09:21:54
 Re: 720 gas lower coolant pipe in reply to Chaterman, 03-08-2005 14:12:21
Of all the jobs I performed during a major rebuild of my 70D, one of the toughest was upper and lower water pipe installation. For that I tried many things, but what worked best for me was to cut three or four strips of shim from an old paint can, and then file the burrs off so they were smooth. Then I oriented them lengthways into the bore, so that they would hold the o-ring in place while I pushed the greased up pipe into place. Then I pulled the shims out and it was done. It took less time to talk about it than to do it ! You might want to have an extra o-ring or two on hand to save a trip back to town in case you cut one.
Frank
Mike M
03-09-2005 05:09:45
If these were the pieces you took off there should be no reason they don't go back on. Smear silicone gasket maker on those o-rings and they will slide right together.
freddy
03-08-2005 15:06:39
Just changed mine, WOW that was interesting. New o-rings are just a treat to stick back together. the only way I could get it together is to clean it very well, grease liberally and force together carefully with no gasket at first. Then after it goes together slide a buttered gasket in the 1/4 inch slot. Mine required me to rub the pieced together as I pushed up. Meaning the casting and the head pieces. It would not get together any other way.
