2nd selective control valve for 3010
Eric Harrington
03-08-2005 13:30:39
I am installing a second selective control valve on my 3010. The kit I got from Dennis Polk has what appear to be larger diameter steel hydraulic lines than what is on my tractor. Did the 3020 have the larger lines? Will they be ok to use on my 3010? Will I need different part numbers for the fittings that go into the side of the selective control valve? The part number in my book for the 90 degree fittings is AT35121. And lastly, should the two lines come into the selective control valve on the left or right hand side?
Any help would be much appreciated!
Rodney A. Johnson
03-09-2005 06:44:51
 Re: 2nd selective control valve for 3010 in reply to Eric Harrington, 03-08-2005 13:30:39
Depending upon your kit, you may need to do some drilling and cutting.
I got a secondary hydraulic off of a 3020 at auction. I had to drill holes in order to bolt up the hydraulic coupler bracket in the back. The 3010 had the holes drilled and tapped exactly opposite of the 3020.
In order to get the pipes to fit, you will need to get under the "dash" and cut out a piece of the bracket that the 3010 has to hold the hydraulic lines. This is because the 3010 steel lines run to the bracket and are spliced there. Then another set of steel lines run from the bracket to the back. The 3020 lines are different and will not work on the bracket.
The lines for the 3020 attached on the left hand side. There is a special notch built into the hood that allows for clearance of the lines...course this all assumes JD stock parts. I know it (the hood) looks like it won't fit, but it does.
I think going really slow, it took me all day to put the kit in...was trying to make sure I didn't make any mistakes.
msb
03-08-2005 14:40:24
The 20 series lines were larger, but I think they will go on the tractor O.K..
