70D flywheel
54jim
03-07-2005 19:50:17
My dad has a 70D and the flywheel loosened up and it is junk. The crank is not that bad. Does anyone know if I could find a new flywheel to go on a slightly worn crank ?
bbm5
03-19-2005 18:33:29
 Re: 70D flywheel in reply to 54jim , 03-07-2005 19:50:17
I repaired a loose flywheel using locktight it worked.Heat from a small tourch will remove locktight if flywheel needs to be removed
johndeeregene
03-07-2005 20:04:12
dont even try it. do yourself a favor an just get a tapor lock flywheel. if the splines on the crank are damaged at all then a tapor lock is the only way to go. once you have one you will not have any other problems. an to find a good flywheel you will pay a pretty penny for anyhow. johndeeregene
54JIM
03-07-2005 20:08:50
 Re: 70D flywheel in reply to johndeeregene, 03-07-2005 20:04:12
THANKS! WOULD YOU KNOW WHERE I MIGHT FIND A TAPERLOCK FLYWHEEL?
Duane Larson
03-07-2005 20:26:17
 Re: 70D flywheel in reply to 54JIM, 03-07-2005 20:08:50
54jim,
Call Dave at Allen Machine Works in Jonesborough, TN 423-753-5738 and tell him what you need. That is where they are made.
54JIM
03-07-2005 20:40:07
 Re: 70D flywheel in reply to Duane Larson, 03-07-2005 20:26:17
THANKS DUANE I WILL CALL AND GET ONE ON THE WAY.
720Deere
03-08-2005 05:45:35
 Re: 70D flywheel in reply to 54JIM, 03-07-2005 20:40:07
Definitely go with Allen Machine Works. You will save major money buying direct vs. buying from Dengler or Polk or any other middle man. Shipping is expensive and extra shipping is the cost difference. By the time they ship them to their location and then to you it has incurred at least another $100 in shipping cost.
