4630 engine
DMont
03-07-2005 18:33:17
A neighbor farmer has a 4630 with a hole in the block where a rod came through. Will a 466 bolt in or are there other JD engines that will interchange. Any 404's for sale complete?
DMont
03-08-2005 14:55:31
 Re: 4630 engine in reply to DMont, 03-07-2005 18:33:17
Are there other serious issues besides the extra bolt holes, ie clutch input shaft size, hydraulic pump coupler sizes, anything that will take a lot of expensive machining?
JDBert
03-09-2005 06:30:09
 Re: 4630 engine in reply to DMont, 03-08-2005 14:55:31
Pretty sure you have to change your side rails to get the right amount of engine mounting bolts.
G/MAN
03-08-2005 10:23:30
Yes, a 466 will bolt right in where the 404 currently is. The 466 block will have two more of the 3/4" flywheel housing bolt holes than the 404, but that's not an issue, as they're located higher up on the rear of the block.
