positive ground
alvin
03-07-2005 17:34:32
Am I actualy supposed to put the ground cable on the positive bat post and the power cable to the ground side of the battery on my 1953 50 JD ?If this is true what did I hurt by not doing this .Been having voltage regulator trouble.Is that why. Thanks for any answer Alvin
further info
03-07-2005 19:39:01
 Re: positive ground in reply to alvin, 03-07-2005 17:34:32
a battery by itself does not have a "ground side". the ground only comes into being after you connect a cable from the tractor's frame to a post of the battery. either post of the battery can be connected to the tractor frame and everything will be correct if all other wiring is made for that polarity. probably a more correct term for ground is to call it the "common" side.
John T
03-07-2005 19:06:54
Alvin, it came from the factory wired with the battery + to ground, but many got accidentaly changed over the years. Many VR"s are bi polar and will work either way, while some will not and may suffer eventual harm (contacts burned) if ran reversed. If you wanna go back to its original Positive ground, wire her up, reverse the ammeter leads if necessary due to it reading bass ackwards, then POLARIZE by first dead grounding the Gens Field post to its case, then momentarily flash jump a wire from the VR"s BAT terminal over to its ARM (or GEN) terminal and you ought to get a small spark.
Post back any questions, Good Luck n God Bless
John T
alvin
03-07-2005 19:21:11
 Re: positive ground in reply to John T, 03-07-2005 19:06:54
Thanks for the help both of you.Now I know more than I did before .Will give her a try.
billde
03-07-2005 17:55:15
Alvin, yes the pos terminal should be hooked to ground. You probably haven't hurt anything, just change your cables, polarize your system, and it should start charging. {Unless it has been converted to alternator in which case there may be a problem.}
